Old 06-13-2014, 11:44 AM
lr172 lr172 is offline
Default Finding Relevant AD's &SB's
I am rebuilding an O-320B1A manufactured in the late 60's.. All my block and cylinder work is done. I would like to review and comply with all the applicable AD's and possibly SB's before assembling it. All the SB's related to the block and crank were completed when the machine work was done by ECI.
Is there an easy way to find AD's and SB's applicable to this engine? The lycoming site only lists SB's back to the mid-90's. I found a post referring me to all AD's on an FAA site, but it is a lot to digest to find what is relevant to my engine.
Old 06-13-2014, 12:07 PM
rocketbob's Avatar
AD's, go to the FAA's website.
SB's, you need all the paper SB's from Lycoming by buying the subscription.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-18-2014, 02:49 PM
osxuser's Avatar
osxuser osxuser is offline
If you are doing this yourself, see if you can create a relationship with a local engine builder/overhauller. They'll have all that data as a matter of course, and can also provide you with some of the hardware you'll need as you move forward. They'll make a little money off you, and you can use them for the data you need.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-18-2014, 03:10 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Check with the Iowa guy building his 320. I sent him my list. Have copies of those if it helps. Bob's right, to get the compete list you needa subscription or, as also recommended a friendly A&P with one to mooch off....
Old 06-19-2014, 10:09 PM
Do you know the User Name of the Iowa guy? Would you mind sending me your list? I'll PM you my email address.
Larry
