Old 01-06-2015, 09:13 PM
1001001's Avatar
1001001 1001001 is offline
Originally Posted by jswareiv View Post
I don't think they go together that way, looks like you are getting the cart before the horse.
Wait till you see where the engine goes!
Old 01-07-2015, 12:11 PM
KHeidorn KHeidorn is offline
I must of read the plans backwards.
Ken Heidorn,
Debur..Dimple..Rivet..Repeat...
"You're never too old to learn something stupid." - unknown
Old 01-09-2015, 06:53 AM
kaber56 kaber56 is offline
Can anyone answer a question for me?
I have received my fuselage kit and before I start I need to know the dimension from the very top of the assembled firewall (angled piece) to the very bottom. I need to know this to ensure the assembly will fit sideways coming out of my basement door. My basement door is 30" wide. I have the aft end finished and will join them in my garage. Thanks!
Old 01-09-2015, 12:05 PM
rvbuilder2002's Avatar
29 1/4 inches
But that is not the tallest dimension of the fwd fuselage.
It is 31 1/2 at the sub panel (about 12 " aft of firewall, don't remember the part #)
If you attach the tail cone to the fwd fuselage while in your basement, the tallest dimension in that case is 36 " (area of the aft baggage bulkhead).
Scott McDaniels
Hubbard, Oregon
Old 01-09-2015, 12:25 PM
N941WR's Avatar
N941WR N941WR is offline
I had the same problem and put in a double door. I wish I had gone wider because I had to remove the landing gear to get it out.
The single door was 32" wide and I doubled it to 64". To get the -9 out the door, we removed the main gear legs, reached in with an engine hoist, and pulled it out. It we would have been much easier to have rolled it ou on its mains or I should have built a ramp and pushed it out on my building stand and then put it back on its gear.
Good luck!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-09-2015, 01:35 PM
Thanks, might have to remove the door jam!
Old 01-11-2015, 10:57 PM
Default Fuselage Riveting
Joined the fuselage halves and mounted the whole thing to the custom engine stands.
The setup allows me to rotate the fuselage as needed.
Now it is time to start riveting the two halves together.
Ken Heidorn,
Old 01-13-2015, 03:22 AM
TedsNumberOneSon TedsNumberOneSon is offline
Ohhh yeahh!!! Build on...this gets me fired up!!!
Terrell Yon
Orlando FL, KCOI Merritt Island Home airport
140173 Kits Underway
Tail kit structurally complete
Wings in progress
N87TY on hold
EAA 724 and 74 Member
Old 01-13-2015, 11:22 AM
bret's Avatar
bret bret is offline
Originally Posted by KHeidorn View Post
Thanks for the compliment. I used to paint cars 25 years ago, the lacquer days. The base coat clear coat system of today is pretty forgiving.
um......only forgiving if you have 25 years painting. I strugled with my paint.
Old 01-13-2015, 10:08 PM
txaviator's Avatar
txaviator txaviator is offline
Chain saw, brutha. Get a chain saw! Repair the door opening later.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
