I have a hose testing rig I built out of a hydraulic screw jack. If anyone wants to come to Cartersville, GA on a weekend, we can test (or destroy) hoses until youre heart is content.
Since I built my own hoses, I tested them to 150% of the value I expect the hoses to see in use.
The interesting issue (for me, anyway) was "Where to stop with the pressure testing?". For instance, if an oil hose might see 100 psi in service, but the hose is rated for 1,000 PSI, do you test to 150 PSI or to 1,000 PSI? Hypothetically, the hose end fitting might hang on just fine to 500 lbs, but might blow off at 501 PSI. Does that really matter to me in my 100 PSI application???
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
