Old 06-10-2014, 07:39 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default FWF Supplies
I'm putting my shopping list together for FWF supplies such as Adel clamps and zip ties...it looks like I will need -12 and -14 Adel clamps and heat resistant zip ties and/or lacing cord...perhaps a roll or two of the silicone self-fusing tape? What else?
Any idea on how many Adel clamps of each size to buy? I haven't got a clue how many I'd need.
All suggestions are welcome!
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 06-10-2014, 09:26 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I usually buy a 10-pack of every size Adel clamp from one of the Fly-Market vendors at Oshkosh each year. I always end up needing more - and those are years when I am not building anything! They seem to evaporate into thin air, along with clecos. There might be something unique about Airpark air that makes stock parts evaporate like that....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-10-2014, 05:59 PM
N282S's Avatar
N282S N282S is offline
Default The rule of Adel clamps
To find the number of Adel clamps you will need, follow this formula:
Number of Adel clamps needed = the number of Adel clamps on hand + 1.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
Old 06-10-2014, 06:04 PM
I finally just broke down and ordered a bunch of different sizes...we'll see how it works!
www.marksrv8.com
Old 06-10-2014, 07:20 PM
cjhammes's Avatar
cjhammes cjhammes is offline
Default Extra all metal lock nuts
An extra dozen or so all metal lock nuts for AN3 bolts and #8 & 10 screws. These coupled with your Adel clamps come in handy as you decide on various wire/cable routings. Stat away from nylocs firewall fwd.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 06-10-2014, 07:22 PM
Thank you...exactly the feedback I was hoping for!
www.marksrv8.com
Old 06-10-2014, 09:23 PM
akarmy's Avatar
akarmy akarmy is offline
Let's see, here's my last few orders... from Stein, McMaster, AircraftSpruce, Vans, B&C, ETC, ETC, ETC
(100468-000) Carb Air Temperature, $37.00 ?-28 UNF,-50? to 150?F
Fuse Holder, 8-Slot FH-8 1 $15.00 $15.00
D-Sub Plug - 15 Position S8013-15-M 2 $1.50 $3.00
Terminal Insulation Boot MS25171-2S 4 $2.00 $8.00
13-04244 AMATEUR-BUILT A/C CERT KIT 19.950 19.95
13-01134 NORAL DOC HOLDER VELCRO 15.850 15.85
Super-Flex Battery Lead - Black
Configuration: 4-8-5
Connector Type 1: 1/4
Length: 8 Inches
Connector Type 2: 5/16
SBL_BLK 1 $17.00 $17.00
Braided Bonding Strap
Configuration: 4-24-5
Length: 24 Inches
BBS 1 $26.00 $26.00
6AWG White Tefzel Wire
M22759/16-6-9 6 $1.95 $11.70
Impact Crimp Tool
ICT-1 1 $45.00 $45.00
Uninsulated Ring Terminal, 6AWG, .18" Stud
S812-6-3 4 $1.00 $4.00
Uninsulated Ring Terminal, 6AWG, .25" Stud
S812-6-4 4 $1.00 $4.00
Uninsulated Ring Terminal, 6AWG, .31" Stud
S812-6-5 6 $1.00 $6.00
Uninsulated Ring Terminal, 8AWG, .25" Stud
S812-8-4 6 $0.75 $4.50
Uninsulated Ring Terminal, 8AWG, .31" Stud
S812-8-5 6 $0.75 $4.50
Super-Flex Battery Lead - Red
Configuration: 4-14-5
Length: 14 Inches
SBL_RED 1 $17.00 $17.00
5236K882 High-Temperature Silicone Rubber Tubing, Soft, 1/4" ID, 1/2" OD, Opaque Black 3
2.17 per foot 6.51
5117K33 Clear Polycarbonate Barbed Tube Fitting, Reducing Inline Tee for 1/4" X 1/8" Tube ID, packs of 10 1
13.22 per pack 13.22
5117K13 Clear Polycarbonate Barbed Tube Fitting, Tee for 1/8" Tube ID, packs of 10 1
8.92 per pack 8.92
Part Number: AN822-4D
Quantity: 4
Unit Price: 6.36
Part Number: AN823-4D
Quantity: 4
Unit Price: 5.64
Part Number: AN818-4D
Quantity: 4
Unit Price: 0.84
Part Number: AN819-4D
Quantity: 4
Unit Price: 0.65
AWG16-G 16 Ga. Green 30 $0.26 $7.80
AWG18-BU 18 Ga. Blue 30 $0.29 $8.70
AWG16-R 16 Ga. Red 40 $0.28 $11.20
AWG20-W 20 Ga. White Mil-Spec. Wire 40 $0.20 $8.00
SA-1014 15 Pin Female Dsub 1 $0.75 $0.75
SA-1030 Dsub 15 Pin Connector Shell 1 $0.75 $0.75
SA-TS Dsub Backshell Thumb Screw 2 $0.42 $0.84
SA-9900 10 Tab Ground Strip. 1 $1.45 $1.45
SA-701B HEAT SHRINK TUBING 3/32 BLACK 10 $0.30 $3.00
PTT 1/4" Momentary Push Button Switch 2 $2.00 $4.00
SS-2 7/32" Solder Sleeve 10 $0.87 $8.70
Part Number: F-881-1
Quantity: 2
Unit Price: 6.95
Part Number: AN3-4A
Quantity: 10
Unit Price: 0.20
Part Number: AN365-632A
Quantity: 25
Unit Price: 0.18
Part Number: AN365-832A
Quantity: 50
Unit Price: 0.10
Part Number: K1000-08
Quantity: 20
Unit Price: 0.48
Part Number: K1000-3
Quantity: 10
Unit Price: 0.58
Part Number: MS21051-L08
Quantity: 10
Unit Price: 0.75
Part Number: EA OIL COOLER VENT
Quantity: 1
Unit Price: 85.00
Part Number: HW WIRE NUT KIT
Quantity: 1
Unit Price: 9.25
Part Number: CT A-740 BLACK
Quantity: 1
Unit Price: 36.50
Part Number: EA EXHST/COWL SHIELD
Quantity: 5
Unit Price: 5.85
Part Number: PAINT, TOUCHUP PGRAY
Quantity: 1
Unit Price: 4.25
CR3214-4-04 PKG/10 3 (EA) $14.400 per EA 25.0% 0.0% 0.0% 0.0% $10.800 per EA $32.40
1 AN837-6 AN FITTING - STEEL AN837-6 16.850 16.85
1 AN833-6 AN833-6 STEEL ELBOW 14.950 14.95
2 AN924-6 AN924-6 STEEL FITTING NUT 3.970 7.94
10 MS21919-WDG12 CLAMP MS21919-WDG12 0.630 6.30
10 MS21919-WDG14 CLAMP MS21919-WDG14 0.660 6.60
10 MS21919-WDG10 CLAMP MS21919-WDG10 0.440 4.40
10 MS21919-WDG6 CLAMP MS21919-WDG6 0.360 3.60
10 MS21919-WDG8 CLAMP MS21919-WDG8 0.380 3.80
Hope that helps. Like others have said, however much you order, there's always a few more things you will need!
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
Old 06-11-2014, 04:53 AM
Length: 8 Inches
Length: 24 Inches
BBS 1 $26.00 $26.00
Impact Crimp Tool
Length: 14 Inches
2.17 per foot 6.51
8.92 per pack 8.92
Quantity: 4
Unit Price: 6.36
Quantity: 4
Unit Price: 5.64
Quantity: 4
Unit Price: 0.84
Quantity: 4
Unit Price: 0.65
Quantity: 2
Unit Price: 6.95
Part Number: AN3-4A
Quantity: 10
Unit Price: 0.20
Quantity: 25
Unit Price: 0.18
Quantity: 50
Unit Price: 0.10
Quantity: 20
Unit Price: 0.48
Quantity: 10
Unit Price: 0.58
Quantity: 10
Unit Price: 0.75
Quantity: 1
Unit Price: 85.00
Quantity: 1
Unit Price: 9.25
Quantity: 1
Unit Price: 36.50
Quantity: 5
Unit Price: 5.85
Quantity: 1
Unit Price: 4.25
Thanks Andy! I ended up ordering about the same number of the same Adel clamps so that will get me started. I'm going to add the metal lock nuts mentioned by in an earlier post. Very much appreciated!
www.marksrv8.com
