Similar to what I had
That?s similar to what I remember having, about a half inch either side, opposite direction on white gel coat tips. I had rejected fwd and rear ribs along with some fab ( faking the aileron extension) that I used as jigs for revision. My pictures tell me I cut across the back and forward about 16?. I also got to do the second one twice because I twisted it, it had a droop to the outboard edge (half-a55ed Horner tip  ), so watch out for that. I used a few dabs of 5-minute epoxy to get the position set, then went into the real layup. Really, it was not bad and a decently rewarding task, as fiberglass goes.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
