06-06-2014, 02:14 PM
Would you fix this ?
This is the lower rudder faring on my 14A. The fairing is proud of the trailing edge by .010 and is flush at the first rivet. The other side is not perfect, but it isn't as noticeable. Would you fix it?
Barney Johnson
14A #140111
started build 12/24/13
Empennage done, wings done, fuselage done, finish kit in progress.
Dormant 2017, 2018,2019
Back at it 3/20
06-06-2014, 03:40 PM
nope
the only time you will notice it is every preflight inspection and you will learn to smile at it in time. build on.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
06-06-2014, 04:09 PM
I fixed mine, took it all apart and didn't reassemble it until after paint. Now it's off set to the other side
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
06-06-2014, 06:10 PM
Exactly Paul.
Mine was darned near perfect at construction but it wanders every time I take that piece off. Like Steve said too, just smile and go on.
Bill Pendergrass
ME/AE '82
06-06-2014, 07:41 PM
That'd be a pretty trivial fix, I think. Dry micro, contour, sand, fill, and done.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
06-06-2014, 07:51 PM
It is a polyester resin part... Since it is off by such a small amount, I would try some heat (use care not to bubble the gelcoat) and move it into position.
After you get it where you want it, put it through a few more heat/cool cycles to help stabilize it in its new shape (you should hold it in position during each cycle).
Scott McDaniels
Hubbard, Oregon
06-06-2014, 10:16 PM
Sandpaper on the right side, filler/flox on the left side to make everything flush and your done! That's what I would do.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
06-07-2014, 07:50 AM
Considering that it can move depending on installation technique, it might deserve a little experimentation in that area. If you can not adjust via technique, then it will depend on how many offsets you want in your bird.
decisions decisions . . .
Bill
RV-7
Lord Kelvin:
06-07-2014, 10:40 AM
I fixed mine
I did a bit of sanding on my fairing, then laid up some more fiberglass on the inside. Now it sits nice and flush to the rudder skin.
06-07-2014, 01:00 PM
Yes yes yes
Fix it... I'd say that every time you see someone looking over your plane on a ramp somewhere you'll be a tiny bit bothered you didn't fix it during construction. Take the time to follow the preceding advice and fix it now.
Follow this philosophy for the entire build
Just my thoughts
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Dual P-Mags, Airflow Performance matched Injectors, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
