06-08-2014, 04:15 PM
Funny You mention icing...
Kinda like putting decorative icing trim on a cake.
Actually, I found a cake icing kit at a garage sale and used that. It had these syringe-like shooters with several tips and it only cost me $5. I used half of the kit on the left wing and threw the pieces away when I was done and used the remaining half on the right tank and then threw them away. The best 5 bucks I've spent so far...
Rick Vinas
RV7A Emp started 12/09
Wing Kit Arrived!07/31/13
Wing building underway
SEL C/I Pilot
06-08-2014, 04:35 PM
Retaining Ring
The manual says that there is no need to seal the retaining ring, to just rivet it in with the rib and nut plates. Is that adequate, or would some sealant on that part be the better way to go?
-John
RV-7A
Houston (Wings, Tanks)
Reason: Bad Grammar :(
06-08-2014, 04:40 PM
My 2c, I only use PRC (the real "Pro-seal") inside fuel tanks.
http://www.skygeek.com/prc-desoto-ps...lant-pint.html
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
06-08-2014, 05:06 PM
Ring
Originally Posted by compren
The manual says that there is no need to seal the retaining ring, to just rivet it in with the rib and nut plates. Is that adequate, would would some sealant on that part be the better way to go?
-John
RV-7A
What's the retaining ring? The ring around the access hole inside? I sealed it and the floating platenuts I used.
I can't think of any two parts I didn't seal. Any place fuel could escape. If it was inside the tank, I didn't seal it but interior screws and fittings were sealed. Now the access panel... that's another primer war!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
06-08-2014, 05:58 PM
Whatever you do, DO NOT clean up the proseal (or substitute) with MEK or it will leak later on.
Let it harden and sand it smooth before painting.
On the top of my left tank I cleaned off excess pro seal with MEK and that was the only place I had paint blisters.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-09-2014, 08:11 AM
Originally Posted by Walt
Walt, can you elaborate why?
Has anyone had problems using Rick's method of delayed riveting with the newer FlameMaster brand sold by Van's? (I'm inherently messy, so any technique to reduce sealant slop is welcomed.  )
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
06-09-2014, 08:54 AM
Good suggestions all. I'll add one that I found useful. I used the large veterinary syringes to apply sealant, but found them very hard to squeeze by hand. maybe it was because of cool temps in my shop at the time, but eventually I found it was possible to chuck the syringe into a standard caulking gun. That made the squeezing much easier.
Ivan Luke
Hope Valley, RI
RV-7 SB
Just hung the engine!
2020 dues paid
06-09-2014, 10:24 AM
my best tip is to mix 1oz at a time, use large popsicle sticks (purchased at a craft store) to mix, etc... and scoop it into the corner of a baggie. Twist and tape off the excess baggie and then cut the corner. You can then hold and squeeze out just what you need, where you need it. Just like an icing bag.
I also use the acid brushes cut to about 1/4-1/2" so they're stiff to spread the sealant where I want it.
Use lots of sealant to cover and fillet between ribs and skin!
I would NOT seal the cover with proseal. (tried it... was extremely hard to remove) I also didn't have good luck with cork gasket (even with proseal on each side) It leaked repeatedly. I'm doing a tank repair now and will use the "access panel" version of proseal found at skygeek this time around. Supposed to be less sticky.
Clay R- RV9A - Flying since 2004 - 400 hours
VAF dues paid through end of 2020.
06-14-2014, 02:50 PM
A lot of good suggestions.
My wife and I put on the old clothes and I already had the ribs fluted and the stands made. Old clothes because that pro seal stuff will jump out and attack you and everything else in sight.
I did the initial. With the filler tank install and the sump drain, and vent line.
We buttered up one rib and clecoed them in place then applied pro seal to each rivet and then riveted it in place and continued until we got them all in. Then we put used a Popsicle stick and edged the ribs. We initially did every other rivet on each rib and then came back and put in the missing rivets before moving on to the next rib Then we put a dab of pro seal around each bucked rivet using bamboo skews and then cleaned up all the excess pro seal on one tank and then started the other.
The next day we did the back plate and the sealed up the rest of the tank it took more time to clean the cleco's and tools and the ribs up than it did to rivet them.
We used the cork seals and even though our latex balloons did not deflate even after 4 months. As soon as I filled them up with fuel one leaked at the cover plate and sending unit.
I removed the cover and the cork and just used pro seal to seal the cover. No more leaks. I did both tanks .
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
06-14-2014, 04:48 PM
Rick's method
That's exactly how I did mine with Vans proseal. They sat for two days before setting rivets. Pressure tested good. No fuel yet so the fingers remain crossed.
Larry Larson
Estes Park, CO
Disclaimer
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
