06-05-2014, 10:40 AM
Help: 7/9 Glareshield GPS antenna's
For those of you have a 7 or 9 with sliding canopy and have placed GPS/XM type antennas on the glare shield, I'd like to get the measurement from the edge of the glare shield.
I'm wrapping up wiring on my slider 7 and would like to set up the antenna locations while I have access to everything. I obviously don't know where the exact location of the forward wind screen will be yet, hence the reason for the question.
Thanks in advance!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
06-05-2014, 02:59 PM
Darwin,
Surprised you have not received an answer.
I don't have a measurement as I am not at the plane but I remember that I set the windshield in place before I decided on a location.
If you are beside the roll bar support slot you can't be too far forward. I have two antenna with one on each side of that support.
06-05-2014, 03:03 PM
Regardless of final position.... think "service loop".
Later, you might be glad to have some extra cable tie wrapped in loops.
You have flexibility on final positioning.... and room to stretch when service is needed. Coax won't care if it is looped. Probably should not cut off excess either, if it is OEM cable and connector.
06-05-2014, 03:07 PM
One other thought.... I read where some builders put it under the cowl. It is transparent to RF. But, hot in there too.
An idea might be to put it under the glareshield... and install a section of RF transparent material in a square cutout when you build the glareshield.
If it is covered by fabric or other... when completion is nearing... the cutout won't show.
06-05-2014, 05:24 PM
Cowl
On my previous 7 I had 3 mounted under the cowl. Worked great. This one will have a 390 and I'm trying to keep things to a minimum up there and that's why I'd like to mount them on the glare shield if possible.
I have completely re-engineered the front structure to provide access by removing the EFIS screens. Everything has a service loop too. This took lots of planning!!!
Not in a huge hurry but if you get a measurement that would be helpful. I won't be to the canopy part for a few more weeks.
Thanks!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
06-05-2014, 06:25 PM
Sent you some pics to your email.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
06-05-2014, 07:13 PM
I have quite the antenna farm on my glare shield. 3 GPS, XM, and a zenonTRx
Hope to play hookie tomorrow early am and get you the dimension you need.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
06-05-2014, 09:07 PM
Pictures
Hi Derek. Haven't received any pictures. Use either ktlkrn@cox.net or ktlkrn@gmail.com
Thanks!!! Appreciate the assist.
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
