Old 06-04-2014, 04:59 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Carbon fiber gear stiffener, good or bad?
I have used carbon fiber for several parts on my -3. It is impressive if applied properly to use the stiffness advantage. My gear has wood stiffeners (rehab project) with fiberglass covers. I read numerous references to "shaky gear" and correct tire pressure. I am aware that carbon touching steel is "no no!
I can fabricate a carbon laminate structure and cover fairing that would be VERY stiff. What say you? Input appreciated.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 06-04-2014, 06:32 PM
vlittle's Avatar
vlittle vlittle is offline
Do we want gear stiffeners or gear dampers? Dampers absorb energy and supress oscillation. Stiffeners do not. Wood will absorb energy due to it's fibrous structure. I don't know if Carbon fiber is as good.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 06-04-2014, 07:33 PM
DanH's Avatar
DanH DanH is offline
I'm with Vern. Graphite/epoxy has about 2x the damping factor compared to stainless steel. Kevlar 49/epoxy would be 30x.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-04-2014, 07:49 PM
Smile good info !
Thanks guys. That is the quality feedback I was looking for!!!
Larry DeCamp
Clinton, IN
