Flame Out - it's worthwhile to keep in mind that many aircraft builders are not electrical wizards. With this point made, I'd hazard a guess and say the fuse was put in line when the builder saw a wire going to the contactor and thought, "gee, that wire is connected directly to the battery!".
The reality is that we normally wire the master contactor such that the +12V side of the coil is hardwired to the battery input, thus our master switch in the cockpit is used to apply a ground to the other side of the contactor coil. When this technique is used (which is just about all the time) the coil of the contactor is acting as the current limiting device. In normal operation with the master contactor closed, you will measure very near 0Vdc at the master switch. When considered in this context, no fuse is required in this wire from master switch to master contactor.
