Old 06-03-2014, 02:03 AM
ron sterba ron sterba is offline
Question Will I need a fuel filter drain on firewall
Rv9A. IO-320 Everything is wired and complete firewall forward. Have Andair electric pump and filter installed just below Andair selector valve. My ONLY place to drain fuel from the fuel system is under the tanks. I'm so use to draining the C-172 tanks and carb drain that I was wondering should I install the fuel/filter drain or a gascolator (2013-14 Page 12 Vans catalog) on the firewall? Again my engine is injected. Seems it would be awkward to clean a filter thats in the cockpit or does it even matter?
Ron in Oregon
Old 06-03-2014, 03:07 AM
spark68 spark68 is offline
Ron,
I'm putting a similar set up in an RV-6 I'm building. IO-320 and Andair pump/filter. My research indicates that no gascolator or filter forward of the firewall is best. Heat soak of the fuel is a problem, and injected engines don't have a float bowl to fill up with water like a carburetor. The water just goes through the injectors. I am however planning on pre-filters in the wing roots. Andair makes a nice one (GAS375) that can be drained. They would act as a pre-filter before the fuel pump.
spark68
Mark Curley
RV-6 (under construction)
dues paid 2020
Old 06-03-2014, 04:26 AM
bobnoffs bobnoffs is offline
please someone explain the difference between a big slug of water in the bottom of a float bowl or a big slug in the bottom of a fuel tank.thanks
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 06-03-2014, 06:24 AM
Sam Buchanan's Avatar
been here awhile
Ron in Oregon
Ron has drains on the tanks but his injected engine has no float bowl.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 06-03-2014, 06:32 AM
brad walton brad walton is offline
I think that is the point being made. The lowest point in the system is the fuel tank drain. No need for other sumps. Cessna and other similar have more than one low points in the system and need drains at each low point.
Old 06-03-2014, 06:37 AM
pierre smith's Avatar
Originally Posted by spark68 View Post
Ron,
spark68
Not quite true. Enough water will stop the engine. We totaled a fuel injected Cessna Agwagon as a result of water-contaminated fuel....yeah, water will go through the injectors but then combustion ceases, no?
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 06-03-2014, 08:13 AM
fixnflyguy fixnflyguy is offline
Default Gascolator/drain
If you choose a gascolator (I have one on my-4) and it stays stone cold even between the pipes, make sure it has an accessable drain, and use it. We witnessed a nearly disasterous Lancair deadstick landing that totaled the aircraft because it was built with a gascolator that had no access with cowl installed. There was 8 oz of water in it when we pulled it apart, although he had just sumped wings,and done full run-up, and even flown the day before. The engine quit during climb out/departure turn.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 06-03-2014, 11:22 AM
Sig600 Sig600 is offline
The reason you get water 99% of the time is condensation. It's why you fill the tanks if the airplane is sitting, to minimize that void and reduce ability for condensation to collect. A fuel injected system has no void beyond the tanks for air/moisture to collect so no I would not, and don't have a gascolator.
If somehow a small amount of water is able to collect in the lines, you would have pulled it through the engine between start up, taxi, run up. Water in the tanks is the threat.
As far as the gascolator above the exhaust pipes, I would be more worried about it developing a leak right onto the hot exhaust. Drains have little rubber o-rings that can wear, fold over, or get debris stuck under them preventing a good seal.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 06-03-2014, 11:51 AM
Bevan Bevan is offline
Ron,
spark68
At least one fuel injection manufacturer requires a fuel filter either immediately before or after the mechanical fuel pump. That could be FWF on a RV.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 06-03-2014, 12:40 PM
bkthomps bkthomps is offline
one is more problematic when it ices up on/around takeoff
