Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 06-02-2014, 07:22 PM
pa38112 pa38112 is offline
Default Stratus in wing tip?
Has anyone tried mounting their Stratus in their wing tip? That seems like a great spot for receiving the signals, but don't know if it will conect to my iphone via wifi?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 06-03-2014, 07:48 AM
AllThumbs's Avatar
AllThumbs AllThumbs is offline
Powering it would require a REALLY long USB cable, or a 12/5v converter close to the Stratus in the wing. Super long USB is prone to loss of both signal and power and is not a good idea. I'd keep the stratus in the cabin where it can see the sky from a shaded position - it doesn't need to be fully exposed at all. Then run a remote 978 mhz antenna to where you can see the ground well.
RV-6 panel is fine. Just... fine.
2019 VAF dues paid!
Old 06-03-2014, 08:53 AM
scard's Avatar
scard scard is offline
The wifi isn't a problem. It works from other airplanes (in formation) .
Scott Card
CMW E-Lift
Old 06-03-2014, 09:31 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
While it is completely possible to mount the Stratus ADS-B receiver in the wingtip, I think you will get better performance and have an easier installation if you install an external 978 Mhz transponder antenna attached to the Stratus unit. I did this in my RV-7 and it was AMAZING the increase in reception I would get. I was even picking up ADS-B on the ground while taxiing.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
