09-30-2006, 04:51 PM
Custom Built Cooling System,,, Composite
Is there anyone that would be interested in custom built cooling tins for the heads and cylinders that fit and are gapped correctly to fit IO-360 angle valve engines that work. Kinda curious to see how many people hate making these things and would like to find a source for custom built ones. If interested let me know.Thanks AJ
10-01-2006, 01:42 AM
Cool what Ya thinking
Hey Allen, to par a phrase, "If you build it and build it good They will come".
I am sure you are aware that Van's sells his Baffle Kit for $230
It's the typical kit and you have to build it up, but it is trimmed to net shape, but you still have to fit. Where you thinking? As far as gap-ping that is something you kind of have to fit on the engine and plane, don't you? However if you have some better idea, I know you do great work, that would be COOL.  (pun intended)
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
10-01-2006, 10:04 AM
Custom Cooling System Composite
Hi George, what I'm looking at is all composite top to bottom, yes it will hold up to the heat. Something I didn't mention was a sealed top plenum as well. As far as the gap between the inner cylinder/head baffle and the baffles that wrap around the cyl/heads, that is a measurement that should be the same on ALL cylinders and heads, hot spots will happen if the gap is not to spec. If that gap is opened up or closed down then the airflow around the cyl/heads is not equal..... you and other pilots are probably aware of that. I've tried all sorts of things with temps probes and heat coloring crayons to see what the temps are around the heads and cylinders etc. Of course Lycoming has done all of this and the lower gap must be kept the same. 2 1/4" on cyl heads and 1" on the cylinders works the best from what I've seen. The the other gap I'm talking about is getting air to flow around cylinder #2 at the front fin area and cylinder #3 at the rear, I've looked at hundreds of RV's and other general aviation aircraft and maybe two out of a 100 are correct and they wonder why #2 and mostly #3 cyls run hotter than 1 and 4. So then what guys do is start blocking air too #1 cyl to get it up to temps like #2 and #3 then deal with #4 running cold. If all of the gaps that I'm talking about are correct, many pilots would see some drastic cyl temp reductions in hot weather and even be able to shut down their air inlets and pick up a little speed. Years ago I heard of pilots opening up or closing the gap on the lower baffles......I was a monkey see monkey do guy back then and I even opened the gap up on one cyl head in 1/2" increments all the way to 4" to try to get more air flow to cool a hot cylinder,,,,,wrong, it made things worse and created hot spots. Probably aware that the changes need to be made on top not the bottom. If you have a mock up engine on a stand with the inner cooling baffles that Lycoming builds in place, then the baffles and plenum can be made to fit perfect around the entire engine, should not make a difference if its in the airplane since nothing is related or fits the cowling except at the cowling air inlets. Aluminum cooling tins are hard to fit the cyl/heads perfect without silicone to seal the areas where a few gaps might be. With the composite baffles they would be molded to fit Lycoming cyl/heads fins perfect. I am aware that Superior / ECI cyl fins are a little different then Lycomings but not much. To protect the composite baffles from eating on the fins or the fins eating on the composite material a high temp spray on rubber type barrier is applied to the cooling shrouds where they are against the fins. Long story short but one would be looking at a low profile top plenum with round inlets, back baffle with all attachments, all baffles that wrap around cylinders as a package. Bolt it on with no trimming cutting making this and that except for scat tubes, plug wire holes and oil cooler cutout. Anyway I've never seen anything out there like this and was looking to see if there is any interest for the RV's. No it will not be $230 lol....This would be a custom fit cooling system for the SJ style cowling for the RV-6,7, 8 with an angle valve 200HP Lycoming. Kinda long story but I hope I explained everything. George, your very up and up on what I'm talking about here so if you have any thoughts or feedback please give me a buzz. Thanks and happy flying. AJ
10-01-2006, 11:52 AM
Sounds like a lot of work when you could simply fab your own plenum top to fit the SJ Cowling using the Vans baffling like I did here for my factory cowling.
-Jeff
10-01-2006, 01:11 PM
Plenum system
Hi Jeff, very nice looking plenum that you built. Yes what I've done is a fare amount of work in the early stages making this that molds etc., but when you have a mold / plug everything can be duplicated very easily. I'm just trying to see if anyone is interested in a prefabbed bolt on cooling kit because I know some builders don't like messing with the cooling system baffles and some or most of them are not designed to work effiecently when they're done. Just trying to help some builders out there. Nice looking system you have there again. AJ
10-01-2006, 02:51 PM
My 2 cents
I guess I would be interested, but I already have the stock cowl so if it's only for the SJ cowl I guess it's not for me...
cheers,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
10-01-2006, 06:05 PM
Baffle
AJ I have a stock 0-360 and Vans cowl and baffling. I would be interested in a top plenum to replace what I have. What would be the cost?
Tad
10-01-2006, 06:38 PM
Wide deck angle valve engine only
At this moment I'm looking at the wide deck Lycoming angle valve engine only. If there is enough interest I would look into it later. Sorry, but thanks for asking. AJ
10-01-2006, 07:21 PM
Tad-
I make and sell them. They are $350.
-Jeff
10-02-2006, 11:34 AM
Plenum
Hey Tad,, I'd go with the top plenum that Jeff makes as it is a very nice looking piece and priced right. Very nice work that you have done on your RV Jeff, looks very nice. AJ
