Old 06-01-2014, 08:57 AM
Bevan Bevan is offline
Default Mags and plugs question
Is there any convention as to which mags fire which plugs? ie Does the left mag typically fire the upper or lower plugs? Both are P-mags in my case, O-360.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 06-01-2014, 09:03 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
What I have usually seen is one mag fires top plugs on one side, bottom on the other side.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-01-2014, 09:39 AM
bruceh's Avatar
bruceh bruceh is offline
Google is your friend. I found this with a quick search.
Bruce Hill
2020 VAF donator
Old 06-01-2014, 02:13 PM
Hadn't thought to ask my friend Mr Google. Thanks!
Bevan
Dual P-mags
Grand Rapids EFIS
Old 06-02-2014, 06:36 AM
krw5927 krw5927 is offline
So what is the purpose of running the tops on one side and the bottoms on the other, with each mag? Why not left mag for bottom plugs, right mag for tops, or vice versa?
Is there a safety or mechanical advantage to splitting them?
Kurt W.
RV9A
FLYING!!!
Old 06-02-2014, 11:51 AM
Just a guess here that the conventional arrangement eliminates differences in RPM drop when doing mag checks. I.e. each mag is firing some tops and some bottoms. Just a guess.
Bevan
Dual P-mags
Grand Rapids EFIS
Old 06-02-2014, 12:33 PM
SHIPCHIEF SHIPCHIEF is offline
The idea is the shortest plug leads go to the bottom plugs.
Right mag to right bottom, left mag to left bottom.
Long leads mean weaker spark. Bottom plugs foul the easiest, so should have the hottest spark available, so, the shortest plug wire.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 06-02-2014, 04:23 PM
Good to know. Each P-mag came a package of 4 plug wires. One long, two medium and one short. I assume that means each one for the appropriate distance to comfortably get to the respective plug.
Bevan
Dual P-mags
Grand Rapids EFIS
Old 06-03-2014, 07:13 AM
Is the difference in spark "strength" really degraded significantly over less than 2 additional feet of plug wire? It seems the Lycoming graphic in one of the above posts actually has the longer leads from both mags going to the bottom plugs. On the "optional" arrangement the shortest leads go to the bottom.
I'm just trying to figure out if there's any sort of safety or operational reason not to fire all the bottoms with one mag and all the tops with the other. I know that a lot of folks running mixed ignitions (one mag, one electronic ignition) are doing just that. Is this a bad idea, and why?
Kurt W.
RV9A
FLYING!!!
Old 06-03-2014, 10:13 AM
pierre smith's Avatar
I have one mag and a Lightspeed plasma ignition system. The mag fires all six lower aviation type plugs and the Lightspeed fires all the top automotive type fine wire plugs.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
