Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-31-2014, 05:31 PM
maus92 maus92 is offline
Default Prop balancing recommended?
I'm looking at buying an RV-8A with a 2-bladed fixed pitch prop. Is it worthwhile having the prop balanced, and how much should it cost? And btw, what exactly do they do? Tape on lead balance weights like I do with my ceiling fans ?http://www.vansairforce.com/communit...lies/smile.gif
Old 05-31-2014, 06:18 PM
Walt's Avatar
Walt Walt is offline
Here's some info from my website:
http://www.expaircraft.com/PropBalance.htm
http://www.expaircraft.com/slideshow1.htm
Yes absolutely worthwhile and I definately don't tape lead weights to your prop
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-31-2014, 08:07 PM
Jesse's Avatar
Jesse Jesse is offline
Another recommendation to definitely balance. Usually weights are added to your ring gear, as most have 1/4" holes every 30 degrees.
Jesse Saint
Old 06-01-2014, 09:05 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I've had my prop balanced on every one of my builds, and I'll have it done on the -12 as soon as I get it painted. It usually makes a significant difference in the vibrations you feel and it's got to be better for the engine and the airframe.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 06-01-2014, 09:44 AM
kinger's Avatar
kinger kinger is offline
I had my prop balanced during my 1st conditional inspection. Very happy I did and have been recommending this to every aircraft owner I know
James King
RV-7
919
Old 06-01-2014, 10:12 AM
Pat Stewart Pat Stewart is offline
Absolutely the right thing to do. Your engine will feel smoother. There will be fewer cracks in things like baffles. The bearings in your engine will thank you. I have had it done on every aircraft I have owned. The last one was my 10 and although it did not require any balancing I at least know its good. Also if you are near Walt give him a call, he will treat you right and he is a very good technician.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
