Go Back   VAF Forums > Education > Close Calls / Lessons Learned
Old 05-29-2014, 02:18 AM
ao.frog ao.frog is offline
Default Most STUPID mistake of all: closed canopy with no one inside! And problem solved!
A couple of days ago, I made a mistake I've been afraid of doing for YEARS.... I managed to close the tip up canopy with the safety lock in the locked position!
Here's how I did it:
I was installing the Kooger Sunshade and during that process I was opening and closing the canopy several times to check the fit of the shade-channel before installing it for the final time.
I was also turning the safety-lock back and forth during the process to verify that the top end of the handle wouldn't interfer with the channel.
During one of the "canopy-lowerings", the handle was in the locked position and suddenly the canopy went all the way down with a small "thump".... AAARRRGGHHH!!!!!
The lock was now preventing canopy-opening just like it's designed to do, so NOW WHAT???? How do I get the canopy open again...?????
As you can see, the extended tip of the handle is pointing forward. That means that the shorter tip is pointing towards the rollbar. This is the ONLY WAY the handle could be positioned to be able to slide past the roll bar and prevent canopy-opening again.
I gathered some people and we all took a close look at the problem: how to turn the safety handle the required 90* so the canopy could be re-opened?
There's no acess from the top because I've installed a weatherstrip on top of the canopy.
One way could be to go through our homemade hatch on the fwd top deck skin (just in front of the canopy)
Another way could be to drill a small hole in the skin just aft of the aft window.
We could drill a small hole on the canopy itself, just above the safetyhandle. Then a small tool could be used to grab the cotterpin in the handle from above and turn the handle.
Then one guy came up with the ultimate sollution: through the slot in the fuse which are for the primary canopy lock!
He cut and bent a alu-channel which looked like this:
Then it was inserted through the slot in the fuse:
Positoned towards the handle:
Then a little pressure was put on the alu-channel, and suddenly the lock turned! Then it was just to put enough pressure on it to make it turn so it was paralell to the rollbar and voila! The canopy could be opened! PHEW!
That ended 30 mins of pure horror- and disaster-thoughts in my head.... YESSSS!!!!!!
Over the years, I've been thinking how to get back into the cockpit if the safety-handle ever schould inadvertently get locked. This could happen when towing, pushing or transporting the plane over a distance, for example to and from the paintshop, or when moving from home to the airport for final assembly.
To prevent this, I've secured the safetylock in open position with gaffa-tape during such moves.
It has never occured to me that it could happen during normal operation of the canopy, but now I know....
So I want to share this with all of you who have tipup's, just in case you'll ever be as stupid as I was....
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 05-29-2014, 05:59 AM
noelf noelf is offline
Many years ago, there was a post on this web site with pictures that showed how to trim the UHMW block that holds the "D" handle and add a spring. The result is such that the D handle is spring loaded in the up direction. When the handle is parallel to the roll bar, the handle nests against the canopy bow and can not turn accidentally. To lock the canopy, pull down and twist 90* as normal.
Noel
RV-6A N6NF
tip-up
flying
Old 05-29-2014, 07:18 AM
rzbill's Avatar
rzbill rzbill is offline
Default Here is my version
Here is a link to my version. There are other ways to do it. Like noelf said, there was a flurry of posts about this roughly 5 years ago that caused me to modify mine.
Tip up lock anti-rotation method
Bill Pendergrass
ME/AE '82
Old 05-29-2014, 07:25 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Brilliant access solution.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-29-2014, 07:30 AM
olyolson's Avatar
olyolson olyolson is offline
Default Closed canopy
I wonder where your buddy learned that trick? I suspect he may be close to my age and remembers how we used to get into our locked cars when the keys were inside, very similar to your predicament. Of course that was back in the day when the locks had little buttons you could grab onto.
In fact, I got a free dinner once from the owner of a Mexican restaurant here in St Louis who was telling me how his car had been sitting in the parking lot all weekend because he locked his keys in it.
Because of my "training" in auto problem solving in high school I was able to get his car open with a coat hangar. You just never know when a previous skill may come in handy building an RV!
Oly
RV-8, Aerosport IO-360M1B, MT 3 blade, AFS 5500
RV grin every flight
"Sure is nice to have smart friends"
Old 05-29-2014, 07:43 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default I had worried about the same thing
on my -6A tip-up. I have been looking at going in through the side vents with a couple of "coat-hangers" type of device ------ have not tried it yet.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A (Sold) Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 05-29-2014, 08:23 AM
paulevans's Avatar
paulevans paulevans is offline
Default Locked Canopy
Anytime I need to shut the canopy completely, I use either a small Velcro loop of tape (soft part of Velcro facing out) and slide over each tip of canopy lock, or a small rubberband over each tip. Prevents the problem from happening all together. I have woken up in the middle of the night thinking of that problem.
Paul Evans
N383Z - RV7
Phoenix AZ
Old 05-29-2014, 09:30 AM
cubdriver cubdriver is offline
Default Locked out
Same thing happened to me 1000 miles away from home on my way to Osh last year. I used a coat hanger which worked perfectly.
Jim Potter - Ramona, CA
RV9A Owner- landed it at Osh on yellow dot
Previous Owner of 1940 J3 Cub
Currently Building RV14a
jim.potter@cox.net
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight." - Elrey B. Jeppesen
Old 05-29-2014, 05:17 PM
Bevan Bevan is offline
Default Is that built per plans?
How is someone supposed to unlatch the canopy from the outside to rescue the occupants in a case of emergency? I wouldn't think that would pass final inspection. The slider canopy can be opened equally from inside or out. Never looked that closely at a tip-up but they should be the same in terms of rescue, no?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 05-30-2014, 05:38 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Bevan
In a situation that requires the occupants to be rescued, the canopy is expendable and easily penetrated
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2021 dues paid
