I sort of remember this from my build.
Once the FAB box is together attached to the carb, and pointed toward the air scoop opening of the lower cowl...
First is to use the foam plug trick to fiberglass an extension to the cowling air scoop. When finished, it should end with a 1/4 to 3/8 inch gap between it and the front of the FAB opening.
The rubber gap seal material will be attached to the FAB front opening. Form the material into a "U" shape with the opening at the top. The sides of the "U" will extend up beyond the side of the FAB some. The amount of this U that you choose to extend forward of the FAB will form a "cradle" around the outside of the extended fiberglass tunnel of the air scoop
Once you are satisfied with the fit of the cowling, FAB box, tunnel, and gap seal so far, and you see how the lower cowling can be raised in place and lowered for removal, then you can cut and position the last piece of gap seal on the forward upper lip of the FAB. It will be trimmed so the forward edge of the gap seal just touches the aft top edge of the fiberglass tunnel.
You can now turn up the outside edges of this top seal so that they lay inside the extended "ears" of the big "U" that you first attached to the FAB. Secure these two extensions together and this will keep the top gap seal from blowing out with your expected 200mph ram air speed.
Noel
RV-6A N6NF
tip-up
flying
