Go Back   VAF Forums > Main > Safety
Old 05-25-2014, 03:51 PM
TomVal's Avatar
TomVal TomVal is offline
Default "Daubers" & Starlets Today...
Interesting day today. It started off with giving a friend a ride to show off my newly installed GRT autopilot.
Next, I helped a Mooney owner install his cowl after maintenance. During the cowl install, we heard a buzzing sound coming out of the left wing. Tapped on the wing, and out flew a mud dauber. Went back to the cowl...a few minutes later...buzz, buzz, buzz...followed by tap, tap, tap...and out flew the mud dauber again. Cowl installed and time for a test hop. Successful test hop followed by buzz, buzz, buzz. This looks like a job for Terminix!
Next, I helped a friend work on his Republic SeaBee. Afterwards I was invited for a test hop. Friend opened the cowl to check the oil and found both sides of the engine impacted with a huge starllng nest. The aircraft remains parked outside and had not flown in over a month.
[IMG][/IMG]
[IMG][/IMG]
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 05-25-2014, 07:13 PM
aerhed aerhed is offline
Starlets nest! I thought they used Airstreams.
Actual repeat offender.
Old 05-25-2014, 07:53 PM
whiskeypapa whiskeypapa is offline
Default Starlets
Dudes,
Starlets stay in 5 star hotels and travel by private jet.
Billy Prouty
RV-4 Prebuilt
Old 05-27-2014, 06:30 PM
Dave12 Dave12 is offline
I was working on the 12 today and just happened to notice a dauber flying around the spinner and before I could get at him, he disappeared in the pitot tube. I quickly pulled the d180 out of the panel and removed the plastic fitting from the rear and gave it a shot of 100 psi air. It appears he shot out of the gun barrel so fast I never saw it. I followed with a piece of safety wire to make sure there was no blockage.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 05-27-2014, 09:42 PM
RV-4 RV-4 is offline
Unhappy Wildlifes
I'll take the bird's problems over the mice's problems I have in my RV-4...
I just don't know what to do to get ride of them...I spent the afternoon cleaning droppings and other stuff out of the aft section and wings...
Do you guys have any good solutions..
I thought about putting one of these in the aircraft...might work..
http://www.bird-x.com/transonic-pro-...hp?page_id=137
Help
Bruno
rv4@videotron. ca
Old 05-27-2014, 09:48 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Same thing here in a wing fuel line. It was a good thing no one was standing in
front of it as I would be in jail now for murder
Nigel
RV9A-N113SQ
52F
Old 05-28-2014, 07:15 AM
precession precession is offline
Help
Bruno
rv4@videotron. ca
I have never tried it, but I think this guy's approach for deterring mice looks like it would work:
http://foresthillair.com/lyonretentionpads.html
Let us know if you try it.
Old 05-28-2014, 07:49 AM
wirejock's Avatar
wirejock wirejock is offline
Default Chipmunks
I've not experienced any of those things with an airplane but recently had to remove the AC blower from our truck. A chipmunk used it for winter storage.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 06-08-2014, 03:34 PM
Thumbs up Mices problems
''I have never tried it, but I think this guy's approach for deterring mice looks like it would work:
Reply With Quote''
Hey, might be worth a try...
I tried just about everything so far..
I looked at the tail end section of the aircraft last week with a borescope and found all kinds of deposits in the tail cone and I will be removing the whole empennage this week so I can clean it properly..
The smell is awful...
They must like RVs as I'm the only one with a mices problem on the strip..
Will report back if I go this route..
Bruno
Old 06-08-2014, 07:40 PM
rockwoodrv9 rockwoodrv9 is online now
Im just down the road from this airport. I will have to run up and look at these this week. I like the idea but would rather have them lethal than non lethal. I have been using those stick pad mouse traps all around the wheels of my plane. They work pretty well, but I have to keep replacing them. I would rather just have a whiff of smoke and no more mouse.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
