Old 05-25-2014, 12:43 PM
rapid_ascent rapid_ascent is offline
Default Pitot Fittings
Ok I just started test fitting my Pitot connections using the Safeair kit. I already have a couple of newby questions. And don't say I'm sucking air. Ok corny.
I did a test fit of the tubing by the bellcrank and installed the tubing into the "quick release" fitting. I can't seem to release the tubing now. I pulled back the collar but I can't get the tubing out. I'm afraid to pull back any more on the collar since I might break it. Any tricks here? These aren't one time use right?
The other thing I was wondering about was sealant on the threads of the NPT fittings. What is the suggested method of sealing these threads? Is Teflon tape a no-no? I think I have some sealant that I bought for the fuel lines if I can find it. Something like 767, but I can't remember the number right now.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-25-2014, 02:39 PM
digidocs's Avatar
digidocs digidocs is offline
You're probably thinking of Loctite 567.
David
Old 05-25-2014, 02:54 PM
BillL BillL is offline
There is an o-ring in the fittings so if they were completely dry with no lube then they might stick in the o-ring, just press in the sleeve all the way and twist when pulling, they will come out. I cut the ends with a razor tool from Stein Air and then use some 600 grit to break the edge and avoid possibility of marring the internal o-ring.
Bill
RV-7
Lord Kelvin:
Old 05-25-2014, 03:12 PM
bruceh's Avatar
bruceh bruceh is offline
I think you push in on the collar to release, not pull.
Bruce Hill
2020 VAF donator
Old 05-25-2014, 03:51 PM
FYI, pushing works a lot better than pulling.
Well one stupid question down. What about the sealant or tape?
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 05-25-2014, 05:02 PM
Walt's Avatar
Walt Walt is offline
Teflon tape is fine on pitot/static fittings.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-26-2014, 11:32 AM
Thanks for the responses. Now that I'm finally getting past just bucking rivets there is lots more to learn.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
