Go Back   VAF Forums > The Never Ending Debate Section > Primers
  #31
Old 06-15-2014, 08:10 AM
Husker'87's Avatar
Husker'87 Husker'87 is offline
Originally Posted by diamond View Post
I saw another post that described using AKZO 2111. Is that the same stuff as this?
Also, I see that the PPS comes in different cup sizes. Which cup size is appropriate for priming parts?
I have both the mini and standard. The mini is 6 oz, and the standard are 20 oz. I would think that the standard would be the best and the unit cost is about the same between the two so I would just get the standard size if I had to do it again.
New Pilot
EAA
AOPA
ForeFlight User
RV-10 Empennage Kit Started 5/26/14
http://907TR.blogspot.com
Old 06-15-2014, 12:50 PM
PilotRPI PilotRPI is offline
What guns are people using for AKZO primer? Links would be appreciated. Also, where can people get that PPS system?
I'm ordering the 2 gallons and a couple touch up kits for practice spraying on my practice kits in the next couple days.
Old 06-15-2014, 02:08 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
These guys have been a reliable supplier for me - it's the DeVilbiss version though, not the 3M ones -
http://www.spraygunworld.com/Informa...ups/Dcups.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-15-2014, 03:20 PM
diamond diamond is offline
How about the Harbor Freight version?
http://www.harborfreight.com/5-piece...ups-97098.html
Has anyone used these succesfully for priming? No internal filter or ability to spray upside down, but definately cheaper. How important is spraying upside down and filtering AKZO anyway?
Old 06-15-2014, 03:27 PM
wirejock's Avatar
wirejock wirejock is offline
Default Paint guns
I've read lots of others who used the higher priced HF gravity feed gun. With the 3M PPS cups you can spray any direction.
That said, I love my Devilbiss but I got lucky and bought it used for a great price.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
60av8tor 60av8tor is offline
Save your $ - unless you like watching your Akzo flow out of the $hi!!y plastic treads of the cups. I do use the HF gun (with the cup it came with), however, and get great results for priming.
Jon
Old 06-16-2014, 10:31 AM
Husker'87's Avatar
I got my HVLP gun from Lowes and ordered the PPS cups from Amazon.
New Pilot
EAA
AOPA
ForeFlight User
Old 06-17-2014, 08:10 PM
Mike H Mike H is offline
Jon, if you get out the hangar this weekend stop by and give a lesson on your priming technique. I have a potential sale on the rans so I will be out there installing a Trig transponder and a 406 MHz ELT.
Old 06-18-2014, 05:35 AM
Mike - PM sent
Jon
Old 06-18-2014, 10:25 AM
krw5927 krw5927 is offline
Interesting. I haven't had a problem with any of the HF cups or thread adapters in the two 5-packs that I've used. Economical solution. But I do like the DeKups better.
Kurt W.
RV9A
FLYING!!!
