Originally Posted by randy737
I am using a makerplane axis 25a hub to connect two SkyView displays to :
Dynon mode s transponder
Dynon ADSB
Two Dynon 250 gps
SV intercom 2s
Will I induce electrical noise in my audio system if I run my display audio out from both displays to my audio in to my intercom via the the axis hub?
I recommend running your audio on the AXIS-25A and it works well. It also helps if you follow Dynon's recommendations and terminate both L and R audio with 50 ohms to ground. These 50 ohm resistors can be soldered directly to the AXIS board using the extra holes provided or the can be put on one of your available dsub connectors.
A complete schematic is here:
http://www.vx-aviation.com/sprocket/...ctrical-B1.sch. You will need to install the free software from Expresspcb.com first.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
