Old 05-22-2014, 01:14 PM
TomVal's Avatar
TomVal TomVal is offline
Default Tony T's RV-12 Rudder Gust Lock...
Thanks Tony!
[IMG][/IMG]
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 05-22-2014, 04:51 PM
Ohoho Tom... It looks like a Russian design have you seen wind tunnel comparison tests https://www.youtube.com/watch?v=T22P...ature=youtu.be
Old 05-22-2014, 08:01 PM
TomVal's Avatar
HaHaHa! I totally forgot about about your laboratory evaluation of said device. I have taken top secret additional precautions. First of all, my gust lock serves just a single purpose...to hold the rudder assembly only. Secondly, I have aerospace quality insulation materials inserted in strategic locations in said device to absorb any vibrations transmitted back to the pedal assembly during high wind loading conditions, thus assuring the device would remain in place when subjected to the forces of most commercially available leaf blowers. Thirdly, my rudder is properly attached to the airframe with all hardware as specified in the KAI. Fourth...my hull insurance is current. And lastly...just in case, I keep a For Sale listing at the ready to post...Completed RV12 Minus the Rudder, Available for Sale
Tom Valenzia
RV8 (Sold)
Old 05-24-2014, 07:51 AM
NYTOM NYTOM is offline
Default How does it fit?
Originally Posted by TomVal View Post
Thanks Tony!
[IMG][/IMG]
Can you post a photo with the lock installed. Not understanding how the end fittings attach unless they swivel. Looks like a nice lightweight gust lock.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP
Old 05-24-2014, 08:01 AM
Wink Ok I think I got it, at least on the CCCP version.
Watched the KGB film. Hey they speak English on it! Good lock design and cheap although I guess it takes hours to make. Their lock end that attaches to the control stick appears to be aligned with the stick. Boy, the agent they had operating the wind simulator sure was scary.
Tom Norwood
TMX-O360 FP
Old 05-24-2014, 08:29 AM
TomVal's Avatar
This is a slight deviation from Tony T's design. The photo shows the lock installed. At the rudder pedal end, the T's have weather stripping inserts (left over from the RV12 Canopy Seal Kit). On the opposite end, I just have some fuzzy velcro on the T to protect the interior paint. So between the T's, there is a nice compression fit between the rudder pedals and vertical wall of the seat deck.
This has not gone through extensive CCCP testing. So I would not classify this device in the TSO'd category of approved equipment.
Regards,
Tom Valenzia
RV8 (Sold)
Old 05-24-2014, 03:57 PM
Smagnuson Smagnuson is offline
Unhappy
Ok, on rudder gust locks. I bought one of the high dollar units from anti splat. installed it correctly. had my plane parked at HEN (henderson NV). big wind storm, 50-60 MPH gusts, and guess what? It didn't work. the bottom of the gust lock had disengaged from the rudder pedals, with evidence that aileron and elevator deflection had flexed the gust lock enough for it to come loose. my rudder was slammed into the elevators leaving dents in the rudder and a tweeked elevator. fortunately, i didn't have the plane painted yet, and it was repairable.
Bottom line. Don't trust a single gust lock to hold everything in place. what the demonstration video shows you is a heavy consistent wind pointed only at the rudder, not real wind gusts affecting all the flight controls simultaneously.
The only sure fix is external locks on all the controls and possibly the internal lock on the rudder. For right now, the plane is safely tucked away in my hangar at MKC. no more tie-down parking until I come up with a better system.
Old 05-24-2014, 05:12 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Not sure how effective it would be, but I usually buckle the lap belt around the stick grip to hold the flaperons and stabilator. Thinking that is not the best practice, I am gonna try a simple bungee cord going from the support bar behind the seats, around the stick grip and then back to the support bar. Pretty simple and will allow some movement of the stick if it's super gusty. I have an externa air gizmo gust lock that works on the rudder or the flaperons too. Have to be careful on placemt of that thing as not place it in a vulnerable no rib section.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 05-24-2014, 08:17 PM
DHeal DHeal is offline
An advantage of control locks located inside the cockpit (and obviously in sight when entering the cockpit) is that you are unlikely to forget to remove them prior to flight. External flight locks can be forgotten -- I know it would never happen to one of us'ns , but it has happened many times to others with typically disasterous results.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 05-24-2014, 08:33 PM
Default Rudder gust lock
Ok now if I understand it correctly, it's a rudder gust lock only and doesn't connect to the control stick?
Seems like most of the DYI locks try to combine the rudder pedals and the stick in one unit which is hard when both parts move independently. Yours along with a seat belt tightened around the stick would be pretty effective . I like it.
Tom Norwood
TMX-O360 FP
