Old 05-19-2014, 07:32 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default IFR pitot/static/transponder cert in MN?
Hi All,
I'm coming up on the pitot/static check here in MN and I'd love to use SteinAir's services again but I'm told their test equipment isn't working and likely won't be for a couple of months. As a result, I need to go with option #2 but not sure what that is yet :-)
Anyone have any recommendations for an avionics shop around the MSP/St. Paul area that is RV friendly?
Thanks!
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-19-2014, 08:54 PM
AlexPeterson's Avatar
Originally Posted by ChiefPilot View Post
Hi All,
Thanks!
Brad, these guys have done mine since 2001:
RC Avionics
Address: 8891 Airport Rd NE #7B, Blaine, MN 55449
Phone: (763) 398-3920
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 05-20-2014, 06:47 AM
Scbado Scbado is offline
Default Transponder Check
Give Mark Reiglman a call. 262-994-6706. He will come to you. Mark's prices are very fair IMHO. If you have other people on your field he may even charge you a couple of dollars less.
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
Old 05-20-2014, 11:49 AM
SteinAir SteinAir is offline
Yep...unfortunately the expensive antenna with the special whizbang circuit board inside of it has died...and the replacement besides being thousands of dollars from Aeroflex is some weeks out (not months though) - now you know why these tests are the price they are! Russ and company up at Anoka do fantastic work and I can recommend them....at least until we get our box back up and going.
Stein
