Originally Posted by aeroaddict
Yes, the readability in sunlight has been the issue for the tablets. At this point, I figure I would try the android out as my laptop is old and dying, plus I can try the tablet in the C172 and learn the app while finishing the -7. And by the time I get to the panel phase, who knows, they might have bio-computers.
I bought a mate screen protector had have almost no issues, it gives the screen the same look as the GNS 430/530 and does not have a glare problem.
Android buying tips-
- Try to stay name brand, I went with an Acer B1 it was 116 bucks and it may be a little slow at times but it works great.
- On board GPS is a MUST, if it does not have it dont buy it because now you have to buy a Bluetooth GPS. The GPS is good enough for VFR IFR reverence finding but it is not Garmin quality.
- Bluetooth is a must if you plan of getting a GDL 39 or if your tablet does not have GPS
- 1280X720 is about the lowest screen resolution I would go, any lower and the pixels per inch makes things look fussy.
- 7 Inches is also a good size, I glued the straps of my keyboard to my tablet case. It works great, its just the right size.
- If you buy on the lower end, or buy something that does not have great batter life, get a back up battery, they will run you about 20 to 30 bucks, but it removes it from the ships power to make it legal as a class 1 EFB.
http://www.faa.gov/about/office_org/...fb_job_aid.pdf
