I have a cooling problem in my RV-8A. Cylinder #3 runs very hot on T/O - I've seen that temp spike to ~450 deg before transitioning to cruise/level flight where it settles down to about 360 or so. I should explain that I'm the 3rd owner of the aircraft, and have been modifying it over the past 10 months. Part of the mod process was to replace the non/malfunctioning EGT/CHT gauge with the integrated G3X system, and this is when I discovered the hot cylinder.
Mitigation steps thus far:
1. Replaced the stock baffling with continuous silicon strips. When not in flight, you can see the side baffles drooping away from the cowling, while the rear baffles are compressed against it. Presumably when airflow enters the inlets, the side baffles unfurl to seal the gap. The underside of the cowling has telltale staining - not unlike the Shroud of Turin - that mark where the baffles are rubbing/sealing, and clean gaps where they are not.
2. Seal off the inboard cavity of the inlet ramps formed in the cowling. This was suggested by another builder on my field, so I closed offf the side of the ramps closest to the spinner with fiberglass.
However, there are other issues that I probably need to address, based on the pressure differential discussion in this thread.
There are six blast tubes installed. One on the lower inlet ramp plate for the alternator; two for the mags; one for the battery; one for the fuel pump; and one for the gascolator, all coming out of the back baffle plate. Two questions: Are these blast tubes actually effective, and considering that each of these openings might account for -1" of pressure differential, might they be part of my problem?
The heating system has a 2" scat tube that runs from the back baffle plate, to a muff around an exhaust pipe, to the heater box on the fire wall. When the diverter is closed, it dumps the heated air into the rear of the engine compartment. Based on this thread, it seems to me that this arrangement might have a negative effect on pressure differential.
Anyway, comments are appreciated!
CA
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
