  #21
Old 09-01-2014, 04:42 PM
TTM4 TTM4 is offline
Default 680 Issues
My RV7A had not flown much in the year before I bought it. The 680 was getting weak so I replaced it and also bought a 25A Odessy charger. That was 16 months ago. I fly about 3 to 5 times every two weeks and have had three instances where it would not crank in the past 6 weeks. It seems to charge back up but I no longer trust it. I plan on load testing it later this week and may replace it.
Regardless, I am wondering what, if anything, other folks are using for maintenance? Can you use a Battery Tender Plus? I have no problem leaving it plugged in when I am out of town but I know the literature says to only use their brand charger which I am afraid to leave on constantly.
Tom M.
Old 09-01-2014, 06:34 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I do not leave the battery on the charger any longer than needed to bring it up to charge.
I would not be leaving it on charge while you are out of town for only a week or two----------it should maintain more than enough charge in that short of a time.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-01-2014, 07:06 PM
Gash's Avatar
Gash Gash is offline
I have a PC680 and Battery Tender Plus. I always connect the Battery Tender to the PC680 after every flight. Whether it sits for a day or a week, it's always plugged in no matter what. I've done this without fail for 2 years and have not had any problems whatsoever with the battery. All the literature I've come across says that to ensure long term reliability, you need to maintain the batteries on a float charger. So far I've been happy with the results. Just another data point for you.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 09-01-2014, 07:30 PM
Wayne Gillispie Wayne Gillispie is offline
Tom M.
Try cycling it a few times on the bench. I use a car headlight to run it down, drawing about 4 Amps. Then recharge using a 12 A Odyssey charger. My 3rd one mentioned in prior post drops down to 12.0 vdc after 2-3wks. Odyssey says you can leave them plugged into their list of recommended chargers indefinitely.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-01-2014, 07:54 PM
Mike S's Avatar
Senior Curmudgeon
Good reading here.
http://www.vansairforce.com/communit...d.php?t=108220
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-01-2014, 10:43 PM
Gash's Avatar
Does anyone have experience with the EarthX ETX lithium batteries? (a VAF advertiser) The specs on their website compare favorably to the PC680. I'd like to hear from anybody who has tried going with one of their batteries.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
Old 09-01-2014, 11:05 PM
AltonD's Avatar
AltonD AltonD is offline
Pretty good thread here. I believe EarthX rep comments on the thread as well.
http://www.vansairforce.com/communit...ghlight=earthx
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-02-2014, 12:37 PM
kjlpdx kjlpdx is offline
my pc680 just died after one year, which is why I am reading these posts. I left the master on while the charger was plugged in as well. the battery shows zero volts and I am told it is dead. I have had odyssey batteries before and left the master on and not had problems with recharging them. I use an intelligent charger I bought at batteries plus ($40?). obviously I need a more fool-proof system so that I quit leaving the master switch on [just been lazy not wanting to crawl under the panel]. what I am reading, however, makes me question buying another odyssey battery.
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
Old 09-02-2014, 01:14 PM
Toobuilder's Avatar
My maintenance plan for PC680's is pretty simple - I do absolutely nothing. I got 6+ years out of my first one and didn't even charge it if the airplane sat for a month. All subsequent PC680's have been just as reliable. They just always turn the engine over with vigor. Couldn't ask for anything more from them.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 09-03-2014, 08:04 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
I have connected my Odyssey Battery after every flight for the last 4 -1/2 years to a Battery Tender Plus. Still working great
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
