Old 05-13-2014, 11:29 AM
BillC BillC is offline
Default How fast can you stop smoking?
For those of you who are smokers, how long after you turn off the pump does it take for the smoke stop?
I have a situation where one pipe keeps smoking for several seconds after the pump is turned off. I thought it might be because I didn't have the check valve installed but, even after installing it, I continue to make smoke for some time after the pump is turned off. Is this the norm or do I need to dig deeper?
--Thanks in advance--
Bill
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 05-13-2014, 11:46 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Remember all the discussion about the crankcase oil separators and hooking them up to the exhaust----so the exhaust can create a vacuum and pull the fumes out????
Depending on how your smoke injector is installed, you may be seeing the same thing happening.
Do you have a solenoid valve or are you just switching the pump on and off??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-13-2014, 11:47 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I have the Smoking Airplanes system. The smoke outside the plane coming out of the pipes quits pretty quickly after turning off the switch... maybe a second or two at the most.
The smoke that comes inside the airplane with me lingers much longer than I'd really like
Neal Howard
Airplaneless once again...
Old 05-13-2014, 01:30 PM
Tony Spicer Tony Spicer is offline
If you want the smoke to stop instantly, install a check valve as close to the injector as you can get. There's considerable oil between the injector and check valve in a SA system.
https://picasaweb.google.com/tonyboy...50195064954386
And to roll your own system, have a look at this:
https://picasaweb.google.com/tonyboy...XHwNL-__v2nQE#
Tony
Old 05-13-2014, 01:59 PM
RV7A Flyer's Avatar
[/url]
Tony
How does that fare under prolonged heat from the exhaust and/or engine compartment?
Initially installed the checkvalve that came with the SA kit just forward of the firewall, and that failed (due to heat). Had to move it inside the cockpit.
I see this check valve has a fluoroelastomer seal...wonder how it will survive FF.
Old 05-13-2014, 02:23 PM
Norman CYYJ Norman CYYJ is offline
It entirely depends on your will power.
Old 05-13-2014, 02:25 PM
Survived just fine for several hundred hours of use. Been out of commission for the last three years, though.
https://picasaweb.google.com/tonyboy...10957987220194
Tony
Old 05-13-2014, 04:18 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default You need a solenoid...
We have had the same issue and the check valve is not sufficient to stem the flow once the pump is turned off as the pump loses pressure relatively slowly and the check valve does not close until the pressure is quite low. A solenoid is the only sure way to make the cut-off crisp. The line(s) from the solenoid to the injector should be as short as possible. Six inches of #4 is plenty of line.
Here's a solenoid that will work. It doesn't have to be expensive.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 05-14-2014, 02:15 PM
Thanks Everyone.
Looks like I will be looking into an additional valve or two to be placed closer to injectors.
Bill
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 05-14-2014, 02:17 PM
ronschreck's Avatar
Originally Posted by BillC View Post
Thanks Everyone.
Bill
Bill,
You don''t need two solenoids. Just one with a "T" on the outlet if you have two injectors.
Ron Schreck
IAC National Judge
VAF 2021 Donor
