Old 05-13-2014, 10:40 AM
colinr colinr is offline
Default Alternator Problems
Hi Folks
For some while now we have had an intermittent charging problem on the RV6. I changed the alternator today for a like for like replacement. It is one of the original Vans supplied motor part (30/35 amp) sourced from a Toyota Starlet. The problem is still there which makes me think I will need to replace the control unit. The existing control box has no identifying marks on it .
Can any one help with a pointer in the direction of a suitable replacement control unit.
Colin
Old 05-13-2014, 11:18 AM
N804RV's Avatar
N804RV N804RV is offline
Are you talking about the voltage regulator? Perhaps a picture of the "control unit" in question might help.
A good voltage regulator for homebuilts with 12vdc electrical systems (And nice avionics) is the B&C LR3C-14. Depending on the regulator you have now, you may have to revise your wiring to install it. But, B&C has pretty good install instructions and wiring diagram.
I would make sure your battery is in top shape. The Aero'lectric Connection has a great section on battery maintenance and testing.
Troubleshooting intermittent electrical distribution problems are tough. I tend to approach them with an inspect/clean/rework philosophy. I start at point A and inspect and clean the whole circuit. When I find a potential defect, I rework it and test the system. If the problem doesn't reappear, great. If it does, at least I have eliminated the cheap stuff before replacing expensive components.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 05-13-2014, 11:30 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
From Vans 1998 catalog
ADJUSTABLE VOLTAGE REGULATOR
Different battery technologies require different charging voltages. This small, light 14v solid state unit adjusts easily. 6-32 threaded terminal.
PART NUMBER PRICE
ES M5-150A $45.00
FIXED VOLTAGE REGULATOR
Preset at factory for 13.8v.
PART NUMBER PRICE
ES VR-1751 $36.00
The first one -
http://www.aspwholesale.com/index.ph...productId=2013
The second one -
http://cn.oemol.com/oem/en_oem_detai...Regulator.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-13-2014, 11:42 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
A Ford-type voltage regulator for a late 1970's LTD with 351 thru 460 V8 engine works great with these NipponDenso 35A alternators. From your local AutoZone, O'Reilley's, Pep Boys, etc parts store the "BWD Select" brand part# R400 is about $27. I put one on my RV-6 two years ago and it's working perfect (can't say that for my alternator's mounting brackets at the moment). My original Van's-supplied regulator (square silver metal case with one wire and one screw terminal) failed with only 250 hours on it. The terminals on the Ford-style regulator are labelled I A S and F. Connect it like this: (shamelessly swiped from one of Sam Buchanan's posts)
Wire it like this:
I -- no connection
A -- jumpered to "S"
S -- jumpered to "A", also connected to your alternator switch from the field CB
F -- connect to field terminal of your alternator
case -- securely bonded to ground (i.e. mount on firewall and insure good electrical bonding)
Neal Howard
Airplaneless once again...
Old 05-13-2014, 02:22 PM
walkman's Avatar
walkman walkman is offline
Default ASP Wholesale
I purchased the M150A from ASP a few weeks ago to have one on hand.
It is physically much smaller than the typical "Ford style" VR, and is also adjustable via a little pot on the back side.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 05-13-2014, 03:30 PM
az_gila's Avatar
Smile
Originally Posted by Neal@F14 View Post
...... My original Van's-supplied regulator (square silver metal case with one wire and one screw terminal) failed with only 250 hours on it. ....
That Vans one is a mechanical device, at least the Vans smaller adjustable M5-150A unit is solid state.
Gil Alexander
Old 05-13-2014, 04:16 PM
Neal@F14's Avatar
This is what my original one looked like. The underside was potted in epoxy, sure looked solid-state to me.
http://www.motorcityreman.com/proe88vsjy.html
Neal Howard
Old 05-13-2014, 07:03 PM
rapid_ascent rapid_ascent is offline
Here are 4 Ford type regulators that all have a lifetime warrantee.
http://shop.advanceautoparts.com/web...tage+regulator
http://www.oreillyauto.com/site/c/de...tage+regulator
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-14-2014, 12:39 AM
Many thanks to everyone who has replied.
I think I think I will need to do a rewire job as the existing VR is not like any shown. I can't get a photo at the moment as the a/c is in the hangar 25miles away, but can only describe it as a totally encapsulated unit without any terminals but with flying leads coming from it.
I think I will go for the VR166 solution if I can find one on my side of the Atlantic.
RV6 Slider 0-320 Wooden Chris Lodge Prop
No trees were harmed in the sending of this message...
However, a large number of electrons were horribly inconvenienced.
Old 05-14-2014, 10:24 AM
az_gila's Avatar
Question
Would it be this one from Vans?
IIRC when I got it from Vans the connectors shown in the picture were already cut off and it just had flying leads.
Gil Alexander
