Old 05-13-2014, 09:07 AM
kinger's Avatar
kinger kinger is offline
Default Tip: Simple Riveting
Henrob Self-Pierce Riveting (HSPR) is a process of joining two or more materials from an engineered rivet, unlike conventional riveting, HSPR does not require a drilled or punched hole. HSPR joins dissimilar materials such as steel, aluminum, plastics, composites, and pre-coated or pre-painted materials. Benefits include low energy demands, fast cycle times, no heat, fumes, sparks or waste, providing a great alternative to welding and other fastening techniques.
http://www.youtube.com/user/18004HENROB
http://www.henrob.com
http://www.youtube.com/watch?v=GiB9ff-TSQI
James King
RV-7
919
Old 05-13-2014, 09:27 AM
ppilotmike's Avatar
Default That's friggin' COOL!
Probably way expensive, but how cool...
It's amazing how things are progressing: Originally homebuilders had to do it on their own (designs and all), then they bought engineered plans, then came "pre-punched material kits." Now we're moving from pre-punched material kits to Quick Build kits, and from QB kits to "pulled rivet only" and "no match-drilling required" kits. What could possibly be next?
Mike Rettig
VAF Dues Current
Old 05-13-2014, 11:23 AM
paul mosher
Posts: n/a
Default holes
How are the holes cleaned up? One of the reasons that deburring is needed is that it relieves stress.
I would not think this technique would be a good idea in a aviation application.
Remember stir welding that Eclipse used? A disaster.
Old 05-13-2014, 12:46 PM
ppilotmike's Avatar
Default FSW = "disaster?"
Paul,
Why was using Friction Stir Welding a disaster for Eclipse Aviation? Don't Boeing and several other aerospace companies still use FSW in their manufacturing?
Mike Rettig
VAF Dues Current
Old 05-13-2014, 12:50 PM
horndesign horndesign is offline
ppilotmike ~ Yes, FSW is still being used in commercial aircraft production.
Old 05-13-2014, 12:53 PM
Self-piercing fasteners? Seems like a fatigue problem for sure.
Dave
Eclipse was forced into Chapter 7 liquidation, not as a result of friction stir welding.
Old 05-13-2014, 01:32 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Friction Stir Welding has been used on rocket engine parts and on the Space Shuttle External Tank for many years, very successfully.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 05-13-2014, 01:40 PM
Seems like this thread is misplaced - that rivet sure isn't a tip for building airplanes. More of a way to hang signs on a signpost.
Dave
Old 05-13-2014, 02:55 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Aircraft ready to fly--no assembly required?
Jeff Rich
RV-10 KJVY
N313KC registered
Awaiting Airworthiness Inspection--soon! (fingers crossed)
