Hi Tom,
Very happy with the Fibrefrax :
I installed the firewall doubler on my RV-10 using .016 stainless sheet and Fiberfrax.
Making the stainless box around the control cables was not difficult but stainless does not bend as easy as the materials we are used to working with.
The stainless/Fiberfrax sandwich used on the firewall and the tunnel ,along with the stainless heater boxes has resulted a very cool to touch tunnel and very little radiated heat at my feet.
My aircraft has a very effective A/C unit installed from Airflow-Systems and the low cabin heat from the firewall area was one of my goals.
I am very happy with how it looks and performs .
I used 1/8" Fiberfrax and Type 301 1/42b .016" Stainless Sheet. Thinner sheet would of been better,but it was all that was readily available to me at the time.
3M Fire Barrier 2000 was used to fill in any gaps.
The Eyeball fittings are available from Aircraft Spruce.
http://www.aircraftspruce.com/search...ITTING&x=0&y=0
Very happy with the smooth and maintenance free finish on the inside and out of the firewall.
I was inspired while I was building by Deems Davis (RV-10 ) and Dan H's though testing on his burn rig.
In-flight testing with my insulated firewall,showed that the hottest spots on the firewall are now the engine frame mounting bolts.
There is still an elevated temp area around the closed heat boxes so a diverted valve up stream of the heat boxes would help.
With two summers of North Australian flying,the cabin temps have been very comfy with the A/C consistently being able to have a 10 deg C drop at the vents over outside ambient temps. ( Happy wife = Happy life )
https://goo.gl/photos/Lo9W1kiobwgEUCr5A
The FLIR camera is an attachment to the iphone from,
http://www.flir.com.hk/flirone/content/?id=62910
Very useful for finding failed insulation points and confirming where the heat flows around an aircraft.
Thank you to all that post their collective knowledge on this site to pass on to the next builder.
I'll be visiting Oshkosh for the first time this year and hope to meet many of you that are on these forums.
https://photos.google.com/share/AF1Q...JyTlp0UUxFVnN3
