Old 05-08-2014, 09:44 AM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
Smile Watch that Bolt Torque
Doing my annual inspection and I checked the bolt torques after reading what others on this site said about finding loose bolts. I would never have believed it unless I saw it with my own eyes but I had several bolts loose that needed to be torqued. I only have 68.2 hours on the fuselage! And I did use a torque wrench when I installed the bolts. The bolts I found loose were in the wing, motor mount, and tail section. Wow... I think the protective paint compresses in time under the bolts, "just a theory"..
I want to thank those who share their experiences so we can all learn from them.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
Old 05-08-2014, 04:03 PM
rbibb's Avatar
rbibb rbibb is offline
That is one of the reasons it is advisable NOT to paint under the bearing surfaces of a bolted connection. Mil Specs and such call for masking the area under the washer and bolt head during pre-assembly painting.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 05-09-2014, 06:51 AM
bruceh's Avatar
bruceh bruceh is offline
What about the numerous areas where Van's has you bolting on to powdercoated surfaces?
Bruce Hill
2020 VAF donator
Old 05-14-2014, 08:20 AM
Joness0154 Joness0154 is offline
How about primer? I'm just getting started on my empennage, and I still haven't primed the spars yet. There's some bolted connections on there which I will not prime if that's the case.
RV-7 builder
