Old 05-06-2014, 06:05 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default G3X OAT temp sensor
G3x Team
I am installing a dual screen G3X system in m RV8. I have dual ADAHRS but a single OAT probe. Are the ADAHRS designated primary or secondary?
My real question is does it matter which ADAHRS I hook the OAT probe to? Wiring considerations dictate I hook it to one over the other but I'm not sure if that will have implications during setup later
Thank you
Bob
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 05-06-2014, 06:59 AM
Walt's Avatar
Walt Walt is offline
It's all buried in the manual:
Unit ID:
ADAHRS #1 Leave pins 4 and 5 (of J252) unconnected
ADAHRS #2 Connect pin 4 (of J252) to pin 5 (of J252)
NOTE:
For installations using more than one ADAHRS, ADAHRS 1 must be connected to a GTP 59, but installing additional GTP 59?s for other GSU 25 ADAHRS units is optional. An ADAHRS not connected to a GTP 59 will use temperature data supplied by other ADAHRS as long as both ADAHRS are communicating via the CAN bus.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
