05-05-2014, 06:34 PM
Brake fluid reservoir ?
I have read many comments about the Vans aluminum can. Rocket Bob says no problem. Others have opted for individual cans on the master cylinder like a C140. If I am willing to deal with the Vans can on the cockpit side of the firewall, what am I missing regarding safety and function ?
I understand hoses from TS Flightlines to the caliper is a good thing due to heat. I am only pondering the fluid reservoir to the master cylinder??
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
05-05-2014, 07:17 PM
Larry---not that familiar with the 3, but we can figure a way to mount and plumb the reservoir on the engine side of the firewall if you want.
Tom
Ridgeland, SC
05-05-2014, 10:48 PM
VAF Moderator / Line Boy
We have the individual reservoirs on all three of our planes - they work well, and there are that many fewer connections and hoses.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-06-2014, 04:54 AM
Thanks Paul
What unit are you using ? I see at least two brands and several sizes at ACS .
Larry DeCamp
Clinton, IN
05-06-2014, 07:27 AM
FWIW, I find brake bleeding is more of a hassle and a lot messier with cylinder mounted reservoirs.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-06-2014, 09:09 AM
So easy, even a wife can do it!
Larry, you do have to remove each wheel pant but I find bleeding the remote cylinders easy and (generally) without a mess.
The cylinders we used are similar to Grove Reservoir 067-050. (Ours don't have the black anodizing.
05-06-2014, 10:52 AM
I've just been switching to new master cylinders on my RV-4 and went to the Grove individual reservoirs for the reasons that Paul has said. The reason for the change was to fix a soft brake problem and go away from the 'inverted' master cylinder with the old Clevelands.
The trick that I used to bleed them cleanly was to screw in a nylon NPT to hose fitting in the top of the reservoir and run a length of tube into a bottle to collect the overspill. Then drain out the surplus fluid from the bleed nipple before re-fitting the reservoir cap. I found the nylon fitting at Home Depot.
05-06-2014, 10:31 PM
Cylinder Mounted Reservoirs
Possibly not an issue with the -3's, (or others ?), but as this is in General, and the use in -8's has been mentioned, it's worth pointing out again, the potentially hazardous situation regarding the limited rudder pedal travel. At least in the -8's with in-flight adjustable pedals.
As I see it, you have to either, position the cylinders with a combination of angle fittings, physically limit the pedal adjust mechanism so the most forward positions can't be used, or just placard to warn of the risks  .
Or perhaps just feel comfortable in the knowledge that no one with long legs will ever fly your plane.
Paul.
RV-8 FB, S l o w Build,
180FI, Catto,
Australia.
05-13-2014, 05:26 AM
And you also have a set of these buried somewhere in your new shop
https://picasaweb.google.com/tonyboy...73158994499298
Tony
05-13-2014, 06:55 AM
One plane fitted per plans with firewall reservoir, one plane with individual pedal mounted. Flip a coin..... pluses and minuses to both.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
