05-04-2014, 09:07 PM
PTT on Vans molded grip
Bought Vans budget poly grip. Only need PTT. Can't find a picture or any referrence to the type of switch or how it would be mounted in this grip.
Grip has a recess and what appears to be a keyway slot or anti-rotate slot. I'm thinking there is a switch that this was designed around. I have seen a flat plat mounted to the top of a similar grip but would rather not add to the height.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder ).
05-05-2014, 07:00 AM
stick grip
Hi
I used this grip on my -4. You will find that the top button location is not very ergonomic. I drilled a hole for a button lower down the grip where it is easy for the thumb to push. I used the top hole for my smoke system switch. A dime fits perfectly into that recess so I actually mounted the swtich in a hole in a dime and pressed the dime into the recess.
CM
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
05-05-2014, 09:23 AM
I have never seen a switch with an anti-rotation feature that extends out from the threaded shaft. What I have seen that might work in this application is an anti-rotation washer which has a bent down tab.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
05-05-2014, 10:41 AM
switch orientation.....
....or a 'flat' machined on one or both sides, so the 'hole' is racetrack shaped, and keeps the switch from rotation.
With a PTT..... obviously not an issue.
funny, just had my builder & friend replace the PTT after 6 years and 100 hours, so how many cycles is that?...would be nice to find the buttons from a video game controller, rated at 100,000 frentic pushes!!!
I did like that the new one goes 'click' when you push it....sometimes I'm not sure how far I had pressed the old one, with gloves on for instance.
( I'm sure digikey and such suppliers have the real skookum ones!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
05-05-2014, 10:55 AM
Senior Curmudgeon
http://www.vansaircraft.com/cgi-bin/...=molded-sticks
Top hole is for coolie hat switch, which does need an anti-rotation tab.
Vans says an optional PTT hole may be added.
From the looks of the grip, I would put the PTT in the front, above where your index finger naturally lays. Basically the top of the front bulge area.
Or, get a Tosten grip.
Are you going to install an autopilot?? nice to have a disconnect switch on the stick for an AP----------Tosten has a grip with only two switches, perfect for a PTT and a AP disconnect already installed. http://www.tostenmanufacturing.com/c...aft-grip.html#
I have one in the ten, if you want to see in person.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-05-2014, 08:01 PM
Budget build, Mike. No frills like A/P. Rock sales slow recently...
I read the Vans page when I bought it but assumed if a coolie switch would go in, there should be a momentary to fit the hole also. Maybe do a front button and plug the top hole.
So anyone drill and install a trigger position switch in this grip?
Blain
R-22 sold.
N82 Sierra Tango
05-05-2014, 11:02 PM
Senior Curmudgeon
Got a buddy looking to buy some very soon, will pass on your name to him.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-06-2014, 10:05 PM
Always appreciated
So where will I find a trigger type installation?
Blain
R-22 sold.
N82 Sierra Tango
07-07-2016, 09:17 PM
Reviving old thread
Not in the air yet but I agree with an earlier post that the top mounted PTT is not very ergonomic. Considering drilling for an index finger position. Wondering how others have done it.
Blain
R-22 sold.
N82 Sierra Tango
