Old 05-03-2014, 09:10 PM
LoopDLoop2 LoopDLoop2 is offline
Default Billet Cylinder heads
Well I am getting a little bored again and have thought of building a set of Billet heads for a io360. The heads will use the stock style cylinders and will the stock style valve train. Port locations for now will stay in the stock location. Any thoughts or interest. Started this project a few years back and got sidetracked with live. Tell me what you all think.
Old 05-04-2014, 05:09 AM
Tbone's Avatar
Tbone Tbone is offline
Interesting thought....How will you attach them to the cylinders?
___________
Terry
RV7
XP IO360
Old 05-04-2014, 07:47 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
This was discussed a few years back and it was mentioned that cooling billet heads would be an issue... don't know. Give it a shot.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 05-04-2014, 08:33 AM
BillL BillL is offline
Well this would be a grand opportunity to liquid cool the heads! The barrel attachment might take a little bit of development, air or liquid, but it is an interesting project.
Cooler heads would improve valve cooling, allow some higher compression, and higher operating cylinder pressures to allow turbocharging. One could replace some 360 and 540 with higher blow pressures on something like a 320.
Good luck and keep us posted!!
Bill
RV-7
Lord Kelvin:
Old 05-04-2014, 08:46 AM
SHIPCHIEF SHIPCHIEF is offline
What is the motivating goal?
At 2700 RPM (or a bit more) the improvements to volumetric efficiency can't be great. Perhaps a more efficient combustion chamber or relocated spark plugs?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 05-04-2014, 10:13 AM
DanH's Avatar
DanH DanH is online now
I think Wisconsin is getting a little too much snow.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-04-2014, 11:22 AM
Smile
Yes it ahs been a long winter!!! As far as the attachment to the cylinder. It would be the same for now. Maybe a bolted flange later. Improvements would be a correct chamber. That is where most detonation problems with air cooled engines can be improved on. Valve would be canted for better valve to cylinder wall clearance. A correct short turn radius for better port velocity. I see places like Lycon and Sky Dynamics building some powerful stuff but it could be much better with a little technology. Water cooled out for now. Still wanting simple and light. Cooling will be no problem. Colling fins on my model are more that adequate. There is a bunch of room in cam timing that would help that problem with a correct chamber. So if I put the first set on a Pitts will I be banned for life?
Old 05-04-2014, 04:11 PM
Tony Spicer Tony Spicer is offline
You mean like this?
http://www.liquidcooledairpower.com/cj-overview.shtml
Tony
Old 05-04-2014, 06:00 PM
terrye terrye is offline
Default Billet Cylinder Heads
1. A bolted flange requires a gasket and is just another possible leak path. I'd stay with the shrunken/screwed attachment.
2. Exactly what is wrong with the existing combustion chamber shape? You are limited to 2 valves per cylinder (every air cooled engine that I know about has only 2 valves). So this limits you to a wedge or (semi)hemispherical shape. You also have two spark plugs per cylinder, therefore two flame fronts. Regarding detonation, you're probably aware that a 6" bore is about the limit for control of the flame front, end quenching etc. What are you going to change that will improve the current cruise BSFC of about 0.38?
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 05-04-2014, 06:06 PM
paul mosher
Posts: n/a
Default interesting
Originally Posted by Tony Spicer View Post
Interesting. Are there any flying?
