Old 09-25-2006, 11:10 PM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Steel-jacketed wires: good neighbors?
Hi everyone,
I have some very nice CHT and EGT probes that have steel-mesh-jacketed wire runs coming out the backside. I have run these in bundles along with some other (rubber and tefzel covered) wires.
I am wondering if the steel jackets pose a wear hazard to the other wires in the bundle. The bundles are pretty tight, secured usually every 6 inches, and it doesn't seem like there will be much motion in there, but they are attached to a 2500 RPM vibrating engine...
Paul
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 09-27-2006, 08:44 PM
osxuser's Avatar
osxuser osxuser is offline
It's not ususally a problem, just make sure they aren't fraying.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 09-27-2006, 09:13 PM
az_gila's Avatar
az_gila az_gila is offline
Question Spiral Wrap
If you are concerned, spiral wrap around the metal lines only would work...
http://www.aircraftspruce.com/catalo...spiralwrap.php
Would be an easy fix....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
