Old 05-01-2014, 12:53 PM
Bayou Bert's Avatar
Bayou Bert Bayou Bert is offline
Default FAB and Engine Offset
Working on the FAB and learning as I go.
Following the plans I clamped the two top plates together
and mounted on the FI throttle body or servo or whatever.
I have an O-320-D2G converted to Gami FI.
Wondering just how much have folks had to turn the neck of the
box to center on the intake in the bottom cowl? When I look through
the intake hole on the scoop it I can see that the fuel servo for the FI
is somewhat offset to the pilots side. Guess this is normal?
This makes the edge of the FAB really close to the edge where the recess
for the scoop drops down on the cowl on the pilots side.
On thing, the top plate does line up with the top of the air scoop.
It's just offset a good bit, don't know how to tell how much but its a good
ways from being straight behind the intake.
Does this sound normal?
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2020
Old 05-01-2014, 01:43 PM
bruceh's Avatar
bruceh bruceh is offline
Yes, that is normal to have the FAB hit the snorkel at an angle.
Bruce Hill
2020 VAF donator
Old 05-01-2014, 02:08 PM
JonJay's Avatar
JonJay JonJay is offline
It is not uncommon, depending on your setup, to have to fabricate a new mounting plate so you can offset the airbox to get proper clearance from the lower cowl.
This is not a big deal but offsetting does set up a greater possibility for cracking of the mounting plate.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-01-2014, 02:28 PM
Bayou Bert's Avatar
Default Great Pic
Thanks Bruce for the pic. That saved a thousand words. So on the close side, you air box looks to be what....1.5" from the cowl? Angle looks pretty close too. Yeah!
Bert
RV-9A ?Pearl?
Old 05-01-2014, 02:52 PM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
I had to make a new plate and off set it to line up better. It was no big deal.
Paul Tuttle
RV 8
C-FPVT
Flying.
