Old 05-01-2014, 01:14 PM
digidocs's Avatar
digidocs digidocs is offline
Question Push pull cable end help?
I think I understand how this type of push pull cable end works:
...but I'm not sure I've cracked this one yet. How do you assemble it?
And the real question is, which do you recommend for the end of a parking brake cable?
David
Old 05-01-2014, 01:20 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I used this one on my 10. You may have to use extra washers-----you want to get as much of the slop out of the shank as you can without binding.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-01-2014, 06:10 PM
JimS JimS is offline
Default Second connector would be...
Bolt through hole in arm you are going to control
Washer on the bolt next
Wire from cable control through hole
Second washer
First nut tightened up against washer pinching control cable in the hole
Second nut as a jam nut against the first
JimS
Built and flying a Kitfox IV / 912
Bought and flying an RV-6 / 0-320 FP slider
Built and maintaining a 1800' grass runway
LIVING THE DREAM!!!
Old 05-01-2014, 06:44 PM
grjtucson's Avatar
grjtucson grjtucson is offline
Default B-Nut Better
The first is a standard B-Nut and the cable is held by the set screw.
The second pinches the cable between the head/washer and a washer/nut and is locked by a 2nd nut.
My trouble with the second is that it doesn't swivel. Unless the travel of the control arm and the push/pull are aligned, it won't function without binding. This seems to be for most installations, particularly my parking break and my heater. If there were room for a nut/washer between the head and the hole I think it would work.
I went with B-Nuts.
Hope this helps.
George
George Jenson - http://www.georgejenson.com
Tucson, AZ - N567AJ RV-7 Standard Build
Empennage Completed 1/06, Wings Completed 11/06, Fuselage Done 9/08, Panel Wiring Done 7/19, moved to hangar 10/20. Successful first engine 2/21. AWC 11/11/21. First flights 11/17/21. My first flight ???
Monthly donor, I appear on the list as Jenson Consulting
Old 05-01-2014, 07:27 PM
The second type shown will pivot freely. The wire from the control cable is captured from only the right side (in the picture). If the washer from the left side (up against the control arm) is pinched against the cable wire then a thinner washer is needed. I just replaced my heater control box with a SS one and used the second cable keeper with good success. It pivots nicely.
Not saying one is better than the other, I just used what I had.
JimS
LIVING THE DREAM!!!
Old 12-16-2018, 11:26 PM
mikemalone mikemalone is offline
Just resurrecting an old thread. I purchased a B-Nut from Aircraft Spruce (part #: 05-16245). When I tighten the screw it does not tighten enough to trap the cable (cabin heat cable .05" diameter). The replacement part sent was exactly the same. When I tighten the screw, without a cable being inserted I can't see that the end of the tightening screw even appears in the cable hole. It's like the screw hole hasn't been tapped deep enough. Anyone else experienced this problem.
Mike Malone
RV7 Builder
Worcestershire, UK
Paid-Up 2020
Old 12-18-2018, 07:43 AM
scard's Avatar
scard scard is offline
The second one, by far, has my vote. But I do it kinda' backwards. First, it is just a bolt, no need to place a special order. Second, I treat it as non-adjustable and don't use a hole in the middle, but wrap the cable wire around the bolt a turn or 2 and use a jamb nut to clamp the bolt solid to the pivoting bracket part. The wire wrap then pivots around the bolt. 2000hrs seems to indicate this works pretty well.
Scott Card
CMW E-Lift
VAF Advertiser
Old 12-18-2018, 07:46 AM
rocketman1988 rocketman1988 is offline
Default And
If you use the second, be careful not to over tighten it. It can, and will shear the wire...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 12-18-2018, 10:09 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Cable Ends!
? Or, you could just purchase the really good one, from
Anti-Splat-Aero and be done with it!
https://antisplataero.com/products/b...cable-wire-end
Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 12-18-2018, 07:37 PM
8 Builder 8 Builder is offline
I had the exact same experience as mikemalone. I snapped my 3/32 in. allen wrench off in the set screw, rendering the whole thing useless as I could not get it out. AS&S sent me a new one and the replacement did the job. I also feel that the nut was not tapped far enough to allow the set screw to trap the wire. A few thousandths of an inch made all the difference. Mine is used on the heater door on the firewall.
Rich Snyder
Building RV-8
Superior IO-360
Garmin G3X Touch, VFR
Fixed Catto 3 blade
