Old 04-30-2014, 07:33 AM
MikeyDale's Avatar
Default Grove Brakes
I'm considering installing Grove wheels and brakes on my 7. Has anyone had good or bad luck with them?
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 04-30-2014, 08:03 AM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Not yet
I just purchased the grove wheels and brakes for my -8. They look pretty robust. For the price, I really hope they perform as I have read!
Don
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 04-30-2014, 08:48 AM
Carr Carr is offline
I have them on my RV-8.
I bought the double puck type. Compared to my first 8 that had the Cleveland single puck that comes standard with the kit, the braking was noticeably better at heavier weights.
Be aware that you will have to modify the wheel pants as they are bigger.
Carr
Old 04-30-2014, 08:53 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Love 'em
Been flying with Grove brakes & wheels from day 1 and love them. I installed new brake pads for the 1st time during my annual last year - about 450 hrs.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 05-08-2014, 09:27 AM
BJUST BJUST is offline
Recently upgraded my RV9-A, 1027 hrs, to Grove wheels and brakes. Had to modify the wheel fairing brackets to accommodate the slightly larger caliper assembly. There is a very noticeable difference with increased braking power.
I also recommend Groves tubeless nose wheel assembly Part number 59-19-RV for $349.00. This wheel uses the Aero Classic 11/400-5 8 ply tubeless tire from Desser for $47.95.
Old 05-08-2014, 01:01 PM
vic syracuse vic syracuse is offline
Super Moderator
Default RV-10
Yes, I changed out the Clevelands for the Grove on the RV-10. Much better stopping power and no fade.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-08-2014, 01:05 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Vic, what model of Grove brakes did you use???
I know that some have been changing to the Matco setup--- http://www.matcomfg.com/WHLBRKWI600R...dv-3814-4.html
Just wondering what the specs are on the Grove unit, and cost.
A link to the units you used would be appreciated.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-08-2014, 03:08 PM
mike newall's Avatar
mike newall mike newall is offline
3 airplanes with brakes.
4 Airplanes with undercarriages..
I guess I am happy.......
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 05-08-2014, 03:13 PM
Walt's Avatar
Walt Walt is offline
Grove here as well, I give em a big thumbs up!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-08-2014, 05:18 PM
Super Moderator
Default oops.
My bad. Matco brakes.
Vic
Vic Syracuse
