Old 04-27-2014, 07:39 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Default New product: tie down ring control arm
We have a nifty new product available. We added a tie down ring to the aft end of our control arms. The ring makes it a bit easier to run a rope or chain through the hole compared to wrapping it through the chains and around the tail spring.
tie down control arm web page
Only $25. They also have a deeper locking notch than the standard Van's control arms. Made of tough 4130 steel.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 04-27-2014, 07:42 AM
vfrazier's Avatar
BTW, we also have a similar control arm for use with the RV/Rocket steering link
Steering link
control arm, with tie-down ring, for steering link
Vince Frazier
www.f1aircraft.com
Old 04-28-2014, 07:39 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Vince, check your cart function. The rocket link type when added to the cart....shows up as a standard arm.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 04-29-2014, 08:55 PM
vfrazier's Avatar
Bill,
Thanks for the heads up. Blake says he fixed it.
Vince Frazier
www.f1aircraft.com
Old 04-30-2014, 04:33 AM
Kahuna's Avatar
Kahuna Kahuna is offline
What a great idea Vince. Our ropes get all nasty from the smoke oil mess around the springs and pole. This will eliminate most of that. Plus I can see an easy mount location for the Go Pros. Order on its way.
Kahuna
6A, S8 ,
Gold Hill, NC25
