Old 09-25-2006, 06:36 AM
MXpilot1 MXpilot1 is offline
Default 2 Batteries Required?
I'm due for a new battery, and after reading some older posts I believe I will be switching from Concorde to Odyssey. I noticed that in several posts the authors describe two batteries wired in parallel. Are two batteries required? If so, what is the advantage of going to the odyssey?
Old 09-25-2006, 06:57 AM
pierre smith's Avatar
Default One
Hi guy,
You only need one Odyssey and it's around one third the size of your Concorde and also around 680 amp cranking ability! We have a strong 0-360 with a Catto prop and it spins it fast! It is not a "wet" baterry and can even be laid on its side (from what I've been told).
Some guys want redundancy and they use two batteries....the second one on its own circuit with another switch (in case they lose the primary electrical system).....for the guys with 'glass instrument panels and a must for the guys who use automobile engines like the computer driven Eggenfellner Subarus.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
