Old 04-25-2014, 07:39 PM
SMO's Avatar
SMO SMO is offline
Default Where did you locate the overflow tube from engine driven fuel pump?
I am pondering where to route the overflow tube from the engine driven fuel pump on my IO-540. As I understand this, the purpose of the overflow is to have a place for the fuel to go if the diaphragm starts to leak.
Obviously it would be a bad idea to route it out the cowling exit - the exhaust could ignite the fuel while in flight and I would have a bad day! I was thinking of sending it down the gear leg inside the fairing, but would want to provide an exit before it reached the brake as a fire could start upon landing when using the brakes. Not as bad as a fire in flight, but I prefer no fire at all!
Where did you route your overflow tube from your engine driven fuel pump?
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 04-25-2014, 10:21 PM
bruceh's Avatar
bruceh bruceh is offline
I just followed Van's firewall forward plans.
Plastic tubing tied on with safety wire, then down to the cowling hinge.
Drill a hole in the hinge and bend some aluminum tubing, then secure it to the engine mount.
Bruce Hill
2020 VAF donator
Old 04-25-2014, 11:16 PM
SMO's Avatar
SMO SMO is offline
Thanks Bruce. On a side by side you probably have the width to get enough lateral distance from the exhaust to put this through the bottom. Wonder if the -4 or -8 plans call for a similar placement - much closer to the exhaust - but maybe my concern is ill founded.
Mark Olson
1987 RV-4 Sold
Old 04-26-2014, 12:22 AM
Ironflight's Avatar
VAF Moderator / Line Boy
That's where it is on my -8, and I am pretty sure that is to plans.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
