Tip: Rolling the leading edge of elevator
RV-14
Positioned the 3/4" thin wall conduit at the aft radius of rivet holes and laid the tape on the pipe, tight but not lifting the skin. Used opened eye bolts as seen on this forum.
Results without adjustment
Pulled edge out and down while pushing on the bend.
Good fit with minimal adjustment.
Used to hold skins tight while squeezing rivets
Barney Johnson
14A #140111
started build 12/24/13
Empennage done, wings done, fuselage done, finish kit in progress.
Dormant 2017, 2018,2019
Back at it 3/20
