Old 04-23-2014, 10:23 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default KLX-135 + Dynon EFIS
Is there anyone flying with the KLX-135 (A) feeding GPS data to a Dynon EFIS (D100 series)? If so what settings are you using on the Dynon?
Thanks for the help.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 04-24-2014, 01:25 PM
Darin Watson Darin Watson is offline
Unhappy Does not couple
Did a fair bit of research on this and the short answer is they can not be made to couple. Digital out is non standard and slow, analog out does not work with Dynon.
Regards,
Darin
C-GULF RV-7 located in Calgary, AB
Old 04-24-2014, 01:48 PM
Pmerems's Avatar
Default I found RV's who have been successful
There are a few posts on the Dynon forum that confirm it does work with the dynon systems.
I found this out after I posted the question.
Old 04-24-2014, 10:21 PM
Default Please post link
If so I stand corrected...can you post the link?
Regards,
Darin
Old 04-25-2014, 07:48 AM
Pmerems's Avatar
Default Link
http://dynonavionics.com/cgi-bin/yab...m=1197372076/4
