Why?
Hi Finley,
I'm a little curious as to why you need more clearance.......mud maybe?
One good tip: When you attach the brackets that the axle bolt holds on, mark their location on the fork with a black ink/magic marker line and install nutplates on them. This way you never need to remove the nosewheel when removing the fairings, since the axle bolt will keep the brackets. The lines are so that they can be precisely aligned the next time you change the nosewheel tire (tyre?)
G'day,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
