Old 04-22-2014, 06:58 PM
Default Show your rudder cable exit covers
What did you do to cover exited rudder cables?
Old 04-22-2014, 07:05 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Check out these covers from Avery: http://www.averytools.com/prodinfo.asp?number=10728
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 04-22-2014, 07:35 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I used the Avery ones Rick linked, worked just fine------attached with pro seal.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-22-2014, 07:58 PM
SmilingJack's Avatar
The best picture I could find Vlad.
I had a few scrap pieces and made these and then pro-sealed them on.
John Mastro
RV-8
Old 04-22-2014, 08:07 PM
kinger's Avatar
kinger kinger is offline
http://www.rv7blog.com/2007/03/18/ru...able-fairings/
You could just pro seal them on too
James King
RV-7
919
Old 04-22-2014, 08:13 PM
And that's where I got my plans from! So now I get to say Thanks James!
John Mastro
RV-8
Old 04-22-2014, 08:49 PM
bruceh's Avatar
bruceh bruceh is offline
Default Homemade
I drew up some simple templates on paper, then bent these using a bending brake and hand seamer. The are 3" long and conveniently miss the screw for the interior adel clamp that holds the rudder cable sleeve in place.
The side against the skin is primed. I had to use the back rivet set (with the spring loaded sleeve retracted) to set the tiny "oops" rivets, since the flange isn't wide enough to get the flush rivet set on there. You could always bond these on with proseal instead.
Bruce Hill
2020 VAF donator
Old 04-22-2014, 08:55 PM
Weasel's Avatar
Weasel Weasel is offline
Cool Homebrew fiberglass
[IMG][/IMG]
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 04-23-2014, 10:54 AM
akarmy's Avatar
akarmy akarmy is offline
Used Sam's instructions and made some out of scrap. Then I just pro sealed them in place with no rivets. Worked great.
Rudder Cable Fairings by akarmy, on Flickr
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
Old 04-23-2014, 11:37 AM
Tumper's Avatar
Tumper Tumper is offline
Default Why
Why do you ask this question? Are you about to throw some paint on 666?
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
