Old 04-22-2014, 08:44 AM
Default Tip: This Cradle Rocks!
When I was making the leading edge cradle for my RV-3B, it had to fit on the leading edge while it was on the jig. This led to rounding the front of it.
The pipe interconnecting the two pieces is simply a 18" length of black pipe screwed into flat ends (using epoxy so they'd stay put).
And it rocks!
When I want it to stay in one position, I simply put a C-clamp on one of the wood pieces and that gives me a third leg.
Incidentally, there's a hidden requirement - the wood pieces should be deeper everywhere so that Clecos don't hit the table. These are.
Dave
Old 04-22-2014, 08:47 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default great idea
David, that is a great idea------well worth copying.
I am going to move it to the "Builders Tips" area for future builders to see.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-22-2014, 08:50 AM
wirejock's Avatar
wirejock wirejock is offline
Default Cradle
Well done Dave.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
