Old 04-21-2014, 09:56 PM
John-G John-G is offline
Default Creating a good airframe ground
Van?s plans call for attaching a ground wire to a hole in the seat ribs using a bolt, flat washer and a stop nut to create a ground point for an electrical connector. I?ve already removed the primer down to shiny metal where the mounting hole for the ground wire is located.
My question is ... I?m wondering if there is any merit for substituting the flat washer for a star lock washer with internal teeth? My thinking is the star lock washer will bite into the aluminum, thus creating a better overall ground than just using a flat washer ? especially over time.
However was wondering, in general, if using star washers in a vibrating aircraft is a bad idea? Is there a significant possibility of stress risers being created by the star washer biting into the aluminum?
What is the best way to proceed ... Go with the star washers or install flat washers?
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 04-21-2014, 10:12 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Don't over think it.
Plenty of good grounds flying around without star washers cutting teeth into the aluminum. Use your multimeter to verify the resistance and you'll find that a plain washer is just fine.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 04-22-2014, 06:42 AM
Walt's Avatar
Walt Walt is offline
See FAA AC 43-13 Chapt. 11, table 11-4 for proper ground connecting method (no star washers).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-22-2014, 07:54 AM
Default Will pass on the star washers
Thanks for the input guys. Will move forward using flat washers at ground points and forget about the star washers.
John
www.dogaviation.com
Now Flying!!
