I am a few days away from inspection and my Technical Counselor recommended I had cockpit lighting for my backup instruments. I really do not want to run a bunch of wire right now, any have any good battery powered options that I can clip to the glare shield or mount in my overhead console?
I use one of these battery powered LED lights and at $19.99 a pair they are a great buy. They swivel and pivot like airline reading lights so you can point the beam where you need it. I use Lithium batteries (3 AAA) and change them as part of my Conditional Inspection so they don't run out of power.
Reason: Typo
Hi,
This is Brad Smith welcomes you to this site, here we can find lots of things. For your query I suggest you to contact an expert because right now I have no idea about your question. I am sorry for that??.
??????????.. classified website
We have a full length strip light that's puts out a nice light green illumination of the panel under the glare shield. It's powered off ships power normally but if that fails uses a standard 9 volt battery. I don't however know who made it. I will see if I can find anything next time I visit the plane.
