Old 04-17-2014, 09:10 AM
DaleB's Avatar
DaleB DaleB is offline
Default Cutting fiberglass the right way
Hi guys.
So far every time I have needed to trim fiberglass, it's been non-critical. Either the cut edge was going inside aluminum skins, or I could clean up the edge with a vixen file to get it straight. I have used a die grinder with an abrasive wheel to do the cutting - the results are less than pretty.
Now I'm about to cut the wingtips for the hinge installation method. The edge needs to be nice and straight, and I don't want a gap - so as thin a kerf as possible would be good. So, how would you recommend cutting the tip? I have a Dremel, but don't have a whole lot of confidence in my ability to make a perfectly straight 3' long cut.
I've already got the wing and wingtip drilled for the wider P4 hinge half, and it's clecoed in place. I have thought about making the cut, doing any cleanup with a file as needed, then clamping the flange and hinge back in place before drilling the outboard hinge. Or maybe making some sort of guide that I could use to keep the Dremel aligned with the edge of the fiberglass while making the cut, or using a coping saw to try to keep the cut straighter. What have others done here? I don't want to screw up the wingtip. I think this will look great - but only if the cut is straight and there's not a big gap between the wing skin and wingtip., otherwise it will look like crud.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-17-2014, 09:19 AM
krw5927 krw5927 is offline
Default One way to do it
Make the cut however you want, but leave a little extra material. Get a long, straight board (1x2 usually works fine) and glue 60-grit sandpaper to it with super77 or some other spray adhesive. Use the long sanding board you just made to sand the cut edge down nice and straight to the desired line.
Kurt W.
RV9A
FLYING!!!
Old 04-17-2014, 09:46 AM
DaleB's Avatar
You know, I read that and my initial reaction was, "Well, that won't work, the edges have to match up just right..." Then I thought about it a little more, and realized that you're exactly right. It doesn't matter if the cut-off flange under the wing-side hinge half is a little short, as long as the edge of the wingtip meets up nicely with the wing skin.
Some days I just feel like an idiot for not seeing the obvious. Thanks for the suggestion.
Dale
Omaha, NE
Old 04-17-2014, 11:34 AM
Sig600 Sig600 is offline
I kept a couple of strips of steel stock from Lowes around the hangar for straight edges. Trim the wing tip material just short of your drawn line, the clamp up the steel to your line and sand. It'll make a straight edge and keep you from sanding past it.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 04-17-2014, 11:57 AM
MarkW's Avatar
MarkW MarkW is offline
Kurt is right on. Once you get the hinges fit you will want to make a perfect (or close) fit using a sanding block. I did the hinge thing and love it.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 04-17-2014, 12:50 PM
rocketbob's Avatar
When I put the wingtips on my Rocket using hinges I took magic marker made a wide line around the wingtip half inch or so wide. Then I shoved the wingtip into the end of the wing with a thin scribe while a helper held the wingtip. Scribe along that line and it becomes very easy to see with the magic marker.
Think machinist's ink. Along those lines...pun intended.
Cut with a pair of snips to within 1/4" and sanded the rest of the way to the scribed line with an orbital sander. My tips have virtually no gap.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 04-17-2014, 01:00 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Get a 4 inch wide desktop bench belt sander - the kind with the flat length and curved end. Rough cut near your desired line and the sander does the rest. You will have GREAT control and it beats the snot out of hand sanding to shape. You can find them cheaper than this one. http://www.amazon.com/Rockwell-RK786.../dp/B002CJLV0A
It is the right tool for the job!
Old 04-17-2014, 01:56 PM
BillL BillL is offline
I have been cutting my cowl in the last couple of days and began using the angle head die grinder with a 3-4" cut off wheel. It was windy and cold outside so I went inside and tried my Dremel with a diamond cut off wheel. Huge improvement, in controllability, narrow kerf (not needed here) and cutting ease. Yes, you could probably make a guide to cut better, but this method with a long board sanding block is working great.
Bill
RV-7
Lord Kelvin:
Old 04-17-2014, 03:51 PM
Hornet2008 Hornet2008 is offline
I did mine this way two days ago. I used a Dremel and an Aluminium strap about 3mm thick. Clamped with cleco clamps, cut it along the edge of the recess and smoothed with a 200mm length of pine with 220 grit paper glued on with spray adhesive. They turned out real nice. There is a real good description on a builder's website, which I don,t have with me. PM me if you want the website address.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 04-18-2014, 06:36 AM
flynwest flynwest is offline
I used blue masking tape for the line. Cut just outside the line with the dremal then use perma grit sanding block to get just to the edge of the tape.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
